CoupeVQ35CVT wrote:I have an '09 Coupe 3.5 CVT, with this Y-pipe, as well as a catback exhaust. I did head to head races 0-70 mph and 40-100 mph roll, against another STOCK CVT V6 coupe, and frankly the results were less than impressive. My coupe with $600 in bolt ons had no advantage from a stop. From a roll it seemed like my coupe was SLOWER as Cj's coupe was crawling forard, until about 80-90mph when I noticed I was gaining ever so slowly.
I never noticed anything much after the Y-pipe install other than some sound change, and now after the head to head comparison, I can see gained nothing to write home about practically, or what I'd call "noticeable," but maybe the y-pipe doesn't like the catback (how that even matters makes little sense).
I think a few people are too optimistic/susceptible to the placebo effect of having a new mod and thinking something's gotta be faster. I really hoped this was a 'magic mod' myself, but it's clear to me what this is worth, after even a fully bolted Altima Coupe + BGT tuner in another several race only just gained on me by a few mph, so I shouldn't let it bug me too much. I like the sound, I guess it's one 'noticeable' change.
This may be so. When I installed the y-pipe, it sounded and seemed to feel "different" in that the engine rev'd seemingly quicker. But, I'm not sure of a few things with this car since my excursion to new england dragway last night.
1) My first run of the night was my best run of the night. 14.5xx and that was with a bad 60 time and a little bit of wheel spinning.
2) I had big problems with getting those hankooks to hook up at all last night. Spun every time out of the hole.
3) On the runs where I had less spin, I found that since the CVT heated up so much, it wasn't working very effectively. Maybe its just mine but something was slipping and I consistently was getting 15's even as the temperature dropped during the night.
4) This car definitely limits the throttle around 80 mph. It was noticeable by myself and a friend who i let drive the car.
5) If you don't let your car cool down A LOT, you end up with real bad results. For anyone wanting to go to the drag strip with any frequency, look into getting a transmission cooler.
All this being said, I'm confident that if you could get this car to launch (without breaking the cvt), then you could absolutely pull low 14 into high 13's with this car.
My last two runs of the night, something very weird happened. I'd launch, run down who I was up against, and then right before the 1/4 mile mark I would get tossed forward. It was like the CVT came out of gear and then shifted down once. I did this twice, the first time I did a run with traction control on, so i was wondering if it had something to do with that, and the second time i had it turned off. My belief is that the CVT Control Unit tells it to "cut the crap" once it gets too hot. So i listened to that and didn't run any more, but this is how I come to the conclusion about a transmission cooler.
