RacingLine Header/Y-pipe
Importroller
Car: G35 and 07 Altima 3.5 6spd
rjdmmfl1 wrote:
wow... with times like that, you're whip is almost as fast as Hussain's CVT, even when his car was at stock form...
does no good to have a manual if you don't know how to drive it... who's your daddy now MENDI... I'll tell you who...
THE FAILMATIC CVT IS YOUR DADDY BIATCH...lol
Hussain's car wasn't stock. A removed exhaust system isn't stock. and he is under the assumption that disconnecting his battery made his car drive faster. This is a myth by the way. just disconnecting the battery doesnt erase what the computer has learned in its memory. We tested the theory in my Auto tech course a few years back. Supposedly however, if you disconnected the battery, and held the positive and negative wires together for 30 seconds, it does clear the computer's stored memory cells.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
actually, I'm reffering to his 14.2 that he ran stock... he ran the 13.9 with his exhaust off!
Importroller
On a prepped track the CVT should perform better than a manual. the Manual has too much trouble getting traction right off the line if the driver sucks. on the regular street, I still see the CVT falling short, especially as the speeds start to climb higher.
XXplosive990
Car: 2008 Altima Coupe 3.5 CVT
lol damn my best time was a 14.7 so dissapointed, got an intake and the y pipe and i got the same time as when i was stock runnin wit a full tank of gas. but then again it was 105 degrees today. would the temp make THAT much of a difference though?
mcheddadi
Car: R8
XXplosive990 wrote:lol damn my best time was a 14.7 so dissapointed, got an intake and the y pipe and i got the same time as when i was stock runnin wit a full tank of gas. but then again it was 105 degrees today. would the temp make THAT much of a difference though?
tires man. tires!
hlsd definitly helped me get a good-ish time with my winter tires. with summer performance tires it would have been soo much better. I got tire spin 1st and 2nd gear almost all the way lol
rich2342
Car: 08 Altima Coupe 3.5SE
Driver mod .
A 6 manual sedan is in the mid 13's just the other day at the other board.
marcelo929
Car: 3.5 SE Altima Coupe
ok just got my y-pipe in today took a week not bad. i got my bolts and sticker so im a happy camper
anyone know how long the install takes?
gearhead05
Car: 2008 Nissan Altima Coupe 3.5 SE
marcelo929 wrote:anyone know how long the install takes?
Doesn't take long, about 30-45 minutes.
Importroller
that is why i didn't go to the track this weekend. I had more fun at BW3 and stillen. Just need temps to drop
XXplosive990
yeah i was going around talking to the other drivers there and everyone was all depressed with their times. im thinking the heat was really killing it for everyone
Viper5000
Car: 2009 Altima Coupe 3.5SE/6MT
Quick question to those that have the pipe installed....
Did you re-use the gasket from the old pipe or did you get a new one???
mcheddadi
Car: R8
Viper5000 wrote:Quick question to those that have the pipe installed....
new one
Alien_Tracker
Car: 08 Altima Coupe 3.5SE (Dark Slate)
During the day, it's 115 here. When I go home from work, it's about 90. My AC is much faster at night, when the temp. is lower.
marcelo929
damn and i thought it was hell rising up when we hit 109. i wouldn't be able to live in arizona thats for sure
Importroller
reused. No need for a new one on a car this new
Importroller
I was thinking of going august 1st for the next track day, but its going to be close to 95degrees then too.
And they say there's no global warming! BS
I used to race at Firebird in Phoenix, and 2 days after getting the G from Infiniti of Scottsdale in July we went to the track and it was 115 at 11pm on the track. the best I could pull with the G was a 15.1. HEAT KILLS
marcelo929
sooo i just finished installing my y-pipe. took about an hour or so was having serious trouble getting those damn nuts and bolts of but that was pretty much the hardest part. its a really simple diy just takes time to get those nuts off once they're off its about 15 minutes more or less. raced my friends' volvo c30 and i still beat him more or less by 2 car lengths at around 80 hopefully the y-pipe still has to settle in but i can definetely feel the revs climb much faster all the way to 4k
isaac_b
Car: 2008 altima winter frost white 3.5 SE 6spd MT Premium Package
yea just installed my pipe. no cels
Importroller
rjdmmfl1 wrote:
until you post better trap times.. I will say that the manual is overrated and = FAIL... doesn't matter whether or not its true... if its not true, you have to prove it buddy...lol
Well, how is this for proofMods were Fujita intake, RL Y-pipe, and drag radials.
6spd sedan
r/t:.5760': 1.943330': 5.6151/8: 8.642MPH: 81.191000': 11.2801/4: 13.410MPH: 103.67
rjdmmfl1
6spd sedan
I phucking hate you Sean... stick to grilling at our meets instead of posting your times with your Sedan and that freak motor of yours...
oh yeah, and just to keep repping the superiority of the CVT, I'll say that i dont believe you without an uploaded copy of your track slip like Hussain had.... if you post that, I will concede to the superiority of the manual transmission in the Altima and accept defeat... but until then
your posted times = FAIL without pics!!!
mcheddadi
Car: R8
6spd sedan
drag radials loool! thats cheaping lol.
I wonder what time i'd get with some
marcelo929
ill be heading to the local track tonigh. forecast is 76 so it should be ideal for a good run to see if the y-pipe helps although i must admit im not the best driver at the track, ive only gone once and i did like a 14.8 or 15 ( i know horribe). ill keep you guys updated with how it goes tonight though
Importroller
That aint cheating. Thats being prepared. he runs 13.8s on street tires
Importroller
that wasn't my times. that is someone elses. I came to stillen instead of the track. I don't see my car going any faster than a 13.9-13.8 when i take my system out
rjdmmfl1
if you take your system out, why would it not run faster than a 13.9-13.8?
between your intake, exhaust, and -pipe, on those light wheels you have, plus the system out... shouldn't you be running the same times as your friend?
Importroller
doubtful, he lives in an area with better cooler weather. Plus, traction will be an issue. On street tires, its harder to grip than with slicks or DR. I only have the intake, Y-pipe and mufflers. the catback is basically stock. Mufflers don't add any power. Now, if the temps drop closer to 60-70, I suspect I will be at 13.7-13.8 at over 100mph. my 14.4 run was with my system in the trunk, 20" chromies and crappy street tires.
marcelo929
best time was a 14.72 with 96 degree weather. I seemed to be doing better and better everytime. started at 15.1 and ened at 14.72 hopefuly next time i go i'll break the 14.5. Had the 10 inch sub with its enclosure in the trunk so maybe if i took that out it would help. we'll see
XXplosive990
marcelo929 wrote:Had the 10 inch sub with its enclosure in the trunk so maybe if i took that out it would help. we'll see
haha take out the spare too dude it actually makes a difference, and show up wit less than a quarter tank too. weather is a BIG time killer though
Importroller
I gotta bail on august 1st too, that is the day of my company picnic.
XXplosive990
aww that sucks man, ive been looking forward to seeing other altimas out there. still yet to see one when i've gone
