lolpsi101101 wrote: dont cry.. i use nanos too..
that makes two of us, and more than likely everyone in this forum lolmcheddadi wrote:bump for updates on the Y-Pipes...
WOOT!!!blackteam02 wrote:Hey everyone, i know it might be a little late but i thought id post this email i got from JOE @ racingline performance last night!!!!! ..........
updates were posted on both forums about an hour ago. we met and exceeded our hp goals! final cost are not set yet but expect 275-290 range.
A group buy will also be offered but no set terms have been made as of yet. should be out of the factory in roughly 4 weeks Thanks, Joewww.racinglineperformance.com
Joe I believe the final TQ was of 238 so that is +14 TQ. Or did I type those numbers too quickly on my phone?Racingline wrote:UPDATE!!!
I'm still waiting for the run files to be compiled, plotted etc against the original graphs, but as for numbers................
Baseline w/fujita wai installed(from previous test):232hp224tq
Ypipe V1 w/fujita wai installed(numbers matched todays dyno and previous):238hp227tq
Ypipe V2 w/fujita wai installed:245hp (+13whp)236tq (+12wtq)
Dynos were done at the same shop, same car, same dyno, same operator, and with no correction factors applied!
Well I am saying when I saw my car on the dyno and looked at the read out I recall seeing 238, not 236......I didn't think the dyno graph has been posted yet.......to show that I had been up way to late the night before and got up way to early.....and got the number off by 2 TQ's..... :\phobs wrote:Final TQ is 236 not 238 so Joe's calculations are right, little mistyping on the phone I suppose.
spockrock, what did the low end torque / hp numbers look like? did you loose any low end torque?spockrock wrote:
