if you could give us dB ratings it would be awesome!Racingline wrote:Sorry Guys it's been really busy around here.
Dyno was done on thursday but the results were not as high as expected. Thats' why I didn't rush in to tell everybody.
The car made up to 8hp around 4700rpm and 6hp at peak. But I want more from it. There were 2 factors that contributed to the lower numbers we feel:1) the test car came with it's large and bulky winter rims AND Winter tires, although a minor detail, it does affect the number slightly even if it's only 2hp
2) the pipe the was returned from the benders had a slight deviation from the original design. The merge collector that was supplied had more of a "T" shape to it than a "Y" which we feel is causing some turbulance in the flow, thus hurting numbers.
With all that said the car is going back to the same dyno this coming friday to see how the computer has adjusted after a week of driving and hopefully get a few more ponies out of it. If they show up then the production run will be started with the collector issue fixed. Meaning we'll be claiming "x # of hp" but your likely going to get a few more. I'd rather under rate the part a bit than artificially inflate the numbers like many other companies do.
If the numbers we're looking for don't show up then the car will be put back to stock and we'll wait for a new sample to arrive and start testing all over again.
Cliff notes:
-car made ok power-we're trying to get more from the part before we release it
Careful where you go with this kind of statement. "OUR Y PIPE PROVIDES 15 HP WITH RACING WEIGHT RIMS AND TIRES"Racingline wrote:1) the test car came with it's large and bulky winter rims AND Winter tires, although a minor detail, it does affect the number slightly even if it's only 2hp
Agreed. I completely respect thatFGFCacoupe wrote:very respectable
as excited as I am for this part, please, take your time if it means a higher quality part =)Racingline wrote:thanks for posting Tareeq.
Don't worry guys I'm doing the best I can to make sure you get this part as soon as possible and with the highest quality and best numbers as possible !
we expect 10~15hpit's going to be easyon that scale its a 1 being the easiestyou need an impact wrench, either the 12V plugin to the car type or the electric impact wrench or air tool impack wrench.legend_217 wrote:Ok. so you guys don't satisfy with the result (6-8hp), how much do you expect it to be then ? Is it going to be easy to install ? if the scale is 1-5. How difficult you going to rate it ? How hard to take out stock bolt ?
