Project: Building a SR20DET Head to rev 9000K+ [PICS HEAVY]
URAS
Car: 550hp RB26 in S13 and 450hp rb25 in R32
redtop91 wrote:The only problem I've heard with RAS is that some of the higher end ones chip.
They would only chip if there is another problem, there is never normally meant to be excessive contact between the rocker stoppper and the rocker. To chip a RAS the rocker must be bouncing way to much.... the RAS are not designed to cure valve train faults.
juZz
Have you guys machined more valve clearance to pistons with highlift (11.5mm) cams?
URAS
juZz wrote:Have you guys machined more valve clearance to pistons with highlift (11.5mm) cams?
no need
Slipstream
Car: '94 Sonoma, '90 300zx n/a
ILikeMy240sx: What are your measurements for valve stem height? Just wondering if they are diff from the S15/S14/S13 manuals or not.
juZz
URAS wrote:
no need
What if i go for some overlap?
How much have you tested for lift and advance combinations?
And how much would you recommend advancing/retarding intake/exhaust for a large turbo to spool up good?
Thanks in advance
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Speaking of Valve Float. Heres what i did when over revved (missed shift) to 8krpm with stock valve springs, aftermarket cams, and HLA. Just another reason to run Stiffer Valve Springs and Solid Lifters. Had RAS but there wasnt any saving it when the valves were floating like mine did.
Whats funny is my built head comes out the shop this Friday or Saturday but now i gotta wait till the block gets built now. Definitly going Solid Lifters on the new Head. Oh well, Live and Learn.
S13FASTBACKSR
Car: '92 Fastback SR powered
daaaaaaaaang that is naaassty
C - ROD
Car: SR20DET pignose hatch
that really sucks!
DrifterProdigy85
I look at it as an opportunity to build the block now instead of later. Eliminates me having to do work twice.
C - ROD
im doing my block now, then my head in a few more months
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
I've never done block work before though.
silentvoice71
DrifterProdigy85 wrote:Speaking of Valve Float. Heres what i did when over revved (missed shift) to 8krpm with stock valve springs, aftermarket cams, and HLA. Just another reason to run Stiffer Valve Springs and Solid Lifters. Had RAS but there wasnt any saving it when the valves were floating like mine did.
mm
hahaha in the words of homer mmMmMmMm {drools} valves lol thats looked fun.
C - ROD
so is there any hope for ur head, like can it be machined or are u going to have to replace the entire thing?
DrifterProdigy85
I have a spare head being built at the moment and get it this friday. The is no hope for the stock head. Compression Chamber is too broken up. Also cracked the piston and ****ed up the cylinder wall. Im just gonna build a new block to hold the 600whp that ill be putting to it by winter.
LANOI
Car: K20ITR
I read the rocker arm on stock sr are weak and can break easily when red lineing any truth?
boj240
Car: 93 hatch sr
yeah thats why its really good to do the rocker stopper upgrade and plus easy to do and cheap
DrifterProdigy85
Ive got Greddy Rocker Arm Stoppers on mine and to be honest, i doubt they did anything just because they dont fit tight enough to the Rocker to not make it jump off. I think it all goes back to Valve Float. If the valves float, then the springs arent moving much and when the cam comes in contact with the Rocker, it can make the shims bounce which ends up throwing the Rocker. I could be wrong though.
C - ROD
what kind of valve springs were u running? im assuming stock if u had enough valve float to make the rocker jump off
spider_slayer
Car: S14 240SX
S13 240SX
wow i'm seriously impressed.
DrifterProdigy85
Stock Springs. Only reason the Rocker jumped off was because the Keepers on one of the Exhaust Valves came off. Definitly dont rev above 7500rpm on stock springs. Im proof that bad things happen. Its all for the good anyways. Mazworx is building my block. Already have a built head waiting. Pretty much gonna have a totally new motor now.
C - ROD
getting it done at Mazworx, im sure that thing will be nice
thang nguyen
Car: 1989 Nissan 240SX Fastback
So what's the status on this project???
spider_slayer
Car: S14 240SX
S13 240SX
i'm thinking the same thing.
school is over.
time for an update.
otterman
So.... did this SR ever run or what?
redtop91
He said it was running. And LOL @ your sig.
otterman
Why is there no pics or vids of the car running yet?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
otterman wrote:Why is there no pics or vids of the car running yet?
because he hasnt converted his wheels to legs, yet.
Geno750
LANOI wrote:I read the rocker arm on stock sr are weak and can break easily when red lineing any truth?
Sure, when you install rocker arm stoppers.
boj240 wrote:yeah thats why its really good to do the rocker stopper upgrade and plus easy to do and cheap
No, rocker arm stoppers + hla's = broken rocker arms, see below.
DrifterProdigy85 wrote:Ive got Greddy Rocker Arm Stoppers on mine and to be honest, i doubt they did anything just because they dont fit tight enough to the Rocker to not make it jump off. I think it all goes back to Valve Float. If the valves float, then the springs arent moving much and when the cam comes in contact with the Rocker, it can make the shims bounce which ends up throwing the Rocker. I could be wrong though.
those greddy RAS are likely the reason your rocker arm broke instead of it just poping free and sitting intact in the head.
To avoid all of this people like ILikeMy240sx, and myself went with sla's
ILikeMy240sx
Car: SR Power
hey guys. Car is running fine and it has been running with Solids since my last post. Few things that happened....
1) The head that I received in the mail had bent cam oilers from shipping which I obviously couldn't tell because it was bent slightly. However my cams were able to tell. So my cams broke off the tip of the cam oilers forcing them to make its way down the front cover and in my oil pan.... Sounds sweet haha.
1a) Due to the front part of the cam oiler being knocked off, it starved oil to the intake cam which resulted in metal to metal contact DURING my drive back from Tennessee (NICO meet) to Michigan... yeah... 8 hours of metal to metal contact resulted in #2 lobe on the intake cam to have about 3mm of metal shaved off and rocker arm being destroyed beyond recognition.
1b) The good news is that nothing major damage occurred... just the rocker arm and the cam. The broken oilers have been fished out by dropping the oil pan.
2)So I replaced by intake cam with 260 cam instead of 270 because 270/270 setup was wayyy too much for the turbo I am running (gt2871r .64a/r) and that setup resulted in my full boost occurring at 4500 RPM. 260/270 setup is not much different in terms of when the boost kicks in but I do feel a bit more low end punch. I should have went with 260/260 setup instead... oh well.
3) Also when I measured the valve clearance, some of the clearance opened up a bit but none of them except for couple were out of the recommended clearance range. But I re-shimmed them to .004" clearance and have been running fine since.
S13FASTBACKSR
taesoo sounds great man..what do you suggest as far as cam setup for a gt3071r .63 with tomei solid lifters? thanks bud
