LOL, yeah, that's the number one thing on the list. I'm going to hack it off, and make the WG exit perpendicular. That reverse angle crap isn't gonna cut it.NateDogg wrote:I hope you're planning ahead for boost creep with that dump orientation.
Yeah, looking back, I should have rotated the flange just a bit, but it'll still clear.WDRacing wrote:If I do one, I'll turn the turbo flange a bit "off center" for better alignment. Did you port the hell out of the T2 flange?
WD
Actually, I ended up leaving it as it was. All I have to do is re-route the brake booster vac line, bend the throttle cable just a tad (not enough to hurt it), then mount the WG up there. I'm most likely going to point the vent toward the front of the car, then run the tube (stainless) over the top of the last two runners, down between the manifold and strut tower, then down the back.WDRacing wrote:Did you redo the WG angle?
I'm not opposed to this idea.WDRacing wrote:Screw Tig...just get a gas shielding mig setup. I love mine...
Hit me up anytime. I have the hookup on T3/T04E's for CHEAP with a warranty.eazye2000 wrote:Looks like this may be a project I will be taking on myself here in the near future.. I have a Garrett GT28RS with .86AR right now. I'm looking to go T3 but with the cost of a decent manifold, and reading this, I'm about ready to attempt to tack on a T3 flange and go balls to the wall. I'll have to get in touch with you KATwo40 and talk about this. Exchange idea's.. I'm kinda excited about saving $600+ on a mani!
