Operation: Bottom mount T3/T04E under way!
eazye2000
Car: S13 KA-DET
Yeah, I still have no idea which to get. And I would also need a daughterboard, correct? I'm still waiting for you to come online so I can bug the s**t outta you on AIM.
KATwo40
Car: 1993 240sx KA-T
Sorry, man, I've been hella busy with work and this car...and then toss in the family stuff.
I'll be online for sure, tomorrow night, probably sometime around 7:30-8:00.
KATwo40
Here we go! No laughing at my welds on the SS dump tube. I welded it directly to the wastgate, because there wasn't enough room for the flange.
WDRacing
Not that I'm nit picking your setup. If you would have welded a small portion of pipe to the WG, you could have then welded a flange to that once you made room. Or a Vband clamp setup, or a flex tube with a gapless bandclamp. Thye work very well and allow you to run plumbing anywhere.
I'm only saying this for everyone else considering this project.
Have you had it running yet??
boznuttz
Car: MS13
DETAILS... or else im looking into an oem t28!
KATwo40
WDRacing wrote:Not that I'm nit picking your setup. If you would have welded a small portion of pipe to the WG, you could have then welded a flange to that once you made room. Or a Vband clamp setup, or a flex tube with a gapless bandclamp. Thye work very well and allow you to run plumbing anywhere.
Damn, that's a good idea!
So, where my first weld is, I really should have welded on a flange, then used a mating flange on the rest of the pipe.
Please, don't think I'm gonna whine about getting some criticism. This is called R&D and it takes more than one mind to get things right.
When I first swapped in the STi injectors and retuned accordingly, I had this silly little phantom stumble/flood issue that would happen randomly when coming to a stop/idle. However, despite the "flooding" issue (would only restart if I pulled the injector clips for a few cranks), all AFR's were in check.
Well, after getting my chip burner straightened out, I adjusted the injector lag time from .76ms to .72ms. The car runs and drives like stock! Holy crap, it's so smooth now!
So, yeah, it runs and runs well. This turbo spools up quickly. I'll do some drag racin' tomorrow, get it on video and post it up. Keep in mind, it's a 1/8mi track. Please, don't expect any low 8sec passes, as I'm on street tires with an open diff. But, it'll give an idea of how the car goes.
Logan76
Car: Junk
Nice you finally got it all together, congrats. I like turboxs they make qaulity stuff and their bov's are really loud.
KATwo40
Ok, did a little runnin' tonight.
1. The smell of new exhaust components sucks.
2. This turbo is WAY better than the T3/T04E from agp turbo I used to have. I get 12-13psi by around 3300rpm and it comes on quickly.
3. I love cereal.
WD is gay.
Modified by KATwo40 at 8:56 PM 1/26/2007
eazye2000
Car: S13 KA-DET
Hey, sorry I missed you tonight man. I was burning a pizza in the oven.
KATwo40 wrote:2. This turbo is WAY better than the T3/T04E from agp turbo I used to have. I get 12-13psi by around 3300rpm and it comes on quickly.
That turbo you are talking about here is the one from http://www.teamblindside.com ?
I'm still itching to go T3 but can't find a good manifold to go with. The bottom mount is still 95% gonna happen though. I think I shall follow in the footsteps of a wise man I once knew named KATwo40
KATwo40
Yep, that's the turbo.
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
no boost creep issues with the modifications?
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
daconkiftador wrote:no boost creep issues with the modifications?
Can you explain boost creep? I read it a lot here but no clue what it is? We probably got a good Swedish word for it but don´t know which.
WDRacing
Boost creep is when the wastegate fails to keep the boost at the desired pressure. Usually do to a small opening or poor placement.
WD
Swedish Mike
WDRacing wrote:Boost creep is when the wastegate fails to keep the boost at the desired pressure. Usually do to a small opening or poor placement.
WD
Ah, boost creep actually gives you higher boost then? I thought it was the opposite. Thanks!
WDRacing
Yep, as the rpms increase and exhaust pressure build up, the WG is no longer able to relieve enough pressure. Cause the boost to "creep" up. Somtimes enough to pop a motor.
Swedish Mike
WDRacing wrote:Yep, as the rpms increase and exhaust pressure build up, the WG is no longer able to relieve enough pressure. Cause the boost to "creep" up. Somtimes enough to pop a motor.
We call it boost bolt according to the lexicon, like "the horse bolted."
WDRacing
HAHA...dude, my Boost friggin Bolted man...LOL
Swedish Mike
WDRacing wrote:HAHA...dude, my Boost friggin Bolted man...LOL
Haha, translated wrong? Is there even a word like bolted?
KATwo40
Well, didn't get to run at the track today, as I'm not quite finished tuning, but I can say this...
15psi feels good!
So far, no creep issues. We'll see how she does tomorrow.
WDRacing
Yep bolted can mean has a couple of meanings. Like I bolted down the manifold, or my horse ****ing bolted and I fell off.
DrftPretty
Car: 1988 V8 Mazda Rx7, 1971 Plymouth Road Runner, 2003 Hyundai Tiburon, 1985 Nissan 720, 1975 Jeep Dj5,
You should put together a kit for noobs like myself or at least compile a list SKU #'s and offer to re-flash ECU's and I know I would be willing to send you the money ASAP
Expect a IM from DRFTPRETTY within a few days lol
Dammitboy
Car: 92' Nissan 240
KATwo40 wrote:When I first swapped in the STi injectors and retuned accordingly,
KAT, What size injs. you running? Your project looks fantastic btw.
Kevin
KATwo40
Kevin
Thanks for the compliment.
I'm running 520cc Subaru STi injectors.
Dammitboy
Car: 92' Nissan 240
Anytime, credit where due. I may be scoring a set of the same injectors soon, what did you do for injector harnesses?
Also, I will shoot you an email regarding injector latency, settings etc.
Kevin
jmwenick
Car: 1991 240sx Base Model
KATwo40, where you located? TN? Sweet project by the way.
KATwo40
Dammitboy wrote:Anytime, credit where due. I may be scoring a set of the same injectors soon, what did you do for injector harnesses?
Kevin
You'll need the STi injector clips, but just pin the stock harness into the clips. It's a bit of a pain to get them into the STi clips, but it works. Use beer, when necessary.
Feel free to email me about the settings.
[email protected]
KATwo40
jmwenick wrote:KATwo40, where you located? TN? Sweet project by the way.
Thanks!
I'm in Knoxville. Hit me up if you ever get out this way.
karmakaze
Car: 98 240sx SE
KATwo40 wrote:Thanks!
hey man, i want to weld an external gate onto my bottom mount manifold. think i can come by this weekend and take a look at your setup? (i live in maryville btw)
KATwo40
I'll be out of town this weekend (Telluride CO ski trip FTW!), so it would need to be next week, like Wed. or later.
Of course, if it's not blizzarding tomorrow, you're welcome to come tomorrow.
Shoot me an email:[email protected]
Florida240sx
Only have one size turbo????
