Ranga14 wrote:I get mine today or tomorrow I believe, damn I'm itching to put this on. So noob question and I'm sure it's in the instructions but what does this thing plug into? Any special adapters needed?
And yeah, I'll prolly be calling them and harassing them about those missing features. :P
Yeah well don't count on the documentation that comes with it. It's ok but not great. Since this device works on a lot of other vehicles, the instructions are more general than specific.
This will come with the Tuner, 512mb Micro SD card, OBDII adapter, HDMI cable, power cord and of course the manuals. If you look at the OBDII adapter, you'll see that there is a switch. I didn't notice it at first but if you plug the adapter in and connect the HDMI cable to the tuner, the tuner will come on. That's where the power cable comes into play. If you don't use it, the tuner will be on constantly and the only way to turn it off is to actually remove the cable from it or switch it off by the little switch on the adapter. But if you connect the power cable and connect that to a ACC wire, then it will come on and off with the car.
Don't worry Medhi, I'll be calling them tomorrow. As for the timing, I advanced it +2. I'll keep it there for a bit and see how it works.
