lmfao, fellow /b/rother on the forums?SupahTyTeTwoFowty_y0 wrote:has anyone really been far even as decided to use even go want to do look more like?
I am 16 years old, track only thanks hahaCoupe_love wrote:well, nightsauce.. i appreciate your concern.. the rest of you.. learn some people skills.. this is supposed to be a brotherhood.. not a "16yr old i just got my liscense lets go race our mom's cavalier forum"
have you tried it? you really cant talk s*** till you have. i was always one to talk s*** about it but now i dont see them being bad unless they are done wrongimpact240sx wrote:What is the point in lowering a car? It actually isn't to make it look better like you ricers think, its to improve performance and decrease center of gravity. Cut springs perform worse than oem. Period.
dont talk to my n***a like that! you need to watch it NOOB. be respectfulBrent.S14 wrote:I ride on cut springs....actually, they were on the car when I traded my totaled S14 for it. They suck, a lot. I hate it, the s*** sucks. So guy who wants to be Billy Badass on this forum, shut that s*** up, cut springs suck period. My coil overs are coming in soon, and when I get them, you can have that cut spring crap seeing as you want to be stupid enough to do it. And for what? So your car will be lowered? No? Then why put yourself at risk? Friend of mine died because he cut his springs on his 240, springs eventually broke and bam, slid into another car, then into a pole. So yeah, like I said, shut that s*** up.
hmmm think about that one for a sec...... 2800 pound car by 4 springs at 250 each (250x4=1000 obviously) so my car should be sitting on bump stops when it is on cut springs?? its weird cause when i cut my springs i beat the s*** out of it and never bottomed out once. so kind of like the welded rear end dont talk crap till you have actually tried it. thanks for the almost good info thoughTroubleBound wrote:The cut stock spring takes only 250lb to bottom out, while the stock spring and lowering spring takes 400lb.
this is actually true though. that is why i made a brace to hold the spring in place. and again, its like welding a diff, if you dont have a good weld its dangerous. if you dont brace the spring its dangerous. pretty simple mathTroubleBound wrote:Cut springs do not fit into the spring retainer properly.
Lol i was citing another website for people that aren't to cheap to sacrifice safety smartass. That was the bottom out weight of the SPRING, not the spring/shock assembly. Using your mind boggling complicated math we can figure that 250x4 DOES equal 1000, imagine that, less than 2800 lbs, stock weight. So the stock ones and lowering springs are 400 lbs each right? What is 400x4? 1600 hmmm That STILL seems to be lower than 2800 lbs, the stock weight. SURELY this MUST mean that the car bottoms out from the factory am i right motoman am i right? Har Har Har I don't really care either way i have PBM coils i was just trying to warn the people that aren't to stubborn to use unsafe parts to save money.motoman399 wrote:
motoman399 wrote: thanks for the almost good info though
hmmm your gey. and once again you havent tried it. so stfu with your guesses about how they ride and how "safe" they are.TroubleBound wrote: Lol i was citing another website for people that aren't to cheap to sacrifice safety smartass. That was the bottom out weight of the SPRING, not the spring/shock assembly. Using your mind boggling complicated math we can figure that 250x4 DOES equal 1000, imagine that, less than 2800 lbs, stock weight. So the stock ones and lowering springs are 400 lbs each right? What is 400x4? 1600 hmmm That STILL seems to be lower than 2800 lbs, the stock weight. SURELY this MUST mean that the car bottoms out from the factory am i right motoman am i right? Har Har Har I don't really care either way i have PBM coils i was just trying to warn the people that aren't to stubborn to use unsafe parts to save money.
Maybe there hasn't been an accident due to cut springs yet. Maybe yours will be the first. All we can do is hope.
Of course I've tried it, on two of my s13's a friends neon, and another friends teggy. I wouldn't be talking crap unless i did. I have stance gr+pros....motoman399 wrote:
I agree before some more newb get any more ideas on how to trash more s-chassis.J14cm7 wrote:Dear Mods,
PLEASE LOCK THIS THREAD.
Sincerely,
well no s*** coilovers are better. nobody said that cut springs were superior to anything except stock. so gtfoimpact240sx wrote:I have stance gr+pros....coilovers>cut springsRide qualityPerformanceSafetyAdjustabllity
impact240sx wrote:YOU SIR = Low Budget
