water temp. the stocker is cold, normal, screwed. If this is just going to be a street car with around normal hp (since you're keeping the T25), you should not need to worry about oil temps. It would be good to have both, but for a basic set-up, you need boost/vacuum, water temp, and oil pressure IMO.positron_ wrote:Question, would it be better to have a oil temp or a water temp gauge?
its common for people to use bothpositron_ wrote:Question, would it be better to have a oil temp or a water temp gauge?
real clean,positron_ wrote:
Thanks. Question, are turbo timers necessary. I've been talking to some people and some say yay and some say nay. If you don't use one, how long would you have to let your car idle before you shut it off?chinoS13 wrote:i respect the extent of your build keep it up you inspire many
The basic function of a turbo timer is to allow the vehicle to idle the engine for a timed period, with the ignition key removed. This allows the engine oil and turbo center cartridge to cool down and prevent internal turbo damagepositron_ wrote:Thanks. Question, are turbo timers necessary. I've been talking to some people and some say yay and some say nay. If you don't use one, how long would you have to let your car idle before you shut it off?
speed signal safty feature is where when u try to move the vehicle as its counting down then the turbo timer and engine turn off immediatelypositron_ wrote:Another turbo timer question, when you hook these up can you just plug in the optional harness, wire the power/ground and go or do you have to do the ebrake and speed sensor thing too? If possible I want to avoid that ebrake thing and just use the unit for it's basic function.
haha FTW!duffman1278 wrote:The conversion harness iirc was only setup to install the turbo timer, you still had to wire up the ebrake because the conversion harness only has the plugs for the main harness off the TT. I usually just sit in my car for about 45 sec lol cause I'm a loser haha but I'm going to get one to be on the safe side, and save me time.
Thanks!240life wrote:very nice documentation in this thread people will be able to use this as a reference and calm some of there nerves about the swap
don't rush him240sxHitman wrote:yo man the motor is coming out to look great but like someone else said get this motor dropped in already lol.
Feeler gauges will work to help shim solid lifter's.enterpricorp wrote:I imagine what cody means, by "valve adjustment tool" is a set of feeler gauges.
