well, motor is still in the car as of today. ive had to drive it to and from work the past week. still knocks real bad, but it kind of sounds like its coming from the top end. (not that i actually know)
so im thinking the timing chain guide could have loosened and the chain is just slapping around cause of how loose it is. could that be possible?
because it doesnt usually start knocking till around 2k and higher and sometimes goes away while cruising.
anyways, onto the new motor. i took it apart to clean it and get it ready for all the new gaskets.
top end. kind of dirty, but nothing some seafoam cant fix
besides being dirty, the only thing that bothered me was that lobe in the upper right looks scored
underneath
when i took the pan off, i found out it was held on to the block by RTV only
so i had to order new pan bolts
and if you noticed, heres a close up of the oil pick up...
i guess the PO decided to open things up for more oil flow
either way i ditched it cause i went with the s14 oil pickup.
i got all the new gaskets and bolts waiting to be put on the new motor once the pan bolts get in.
i got Megan motor and trans mounts as well. i really didnt want to go with them, but for all 3, Nismo was almost 500 bucks. and ive been very limited in the finance department when all of this happened.
i got some of these guys too. one for the trans and one for the diff
and i got a new clutch pivot ball cause i forgot to do that last time i had the trans off
im hoping i can get the motor out in the next week or 2. driving it with that knocking sound is really nerve racking/annoying/embarrassing.
