fixed the stupid idler sprocket, got the front cover on today and just went to put the dizzy back in and it wouldnt go in. i was able to get it in by turning the engine over and pushing on it. but i could not turn it, at all. i turned it over some more and it seemed alot harder than before, and then i had to use a mallet to get that damn thing out. what did i f*** up this time?
edit: so i think the idle sprocket isnt exactly lined up from when i helicoiled it. which would be putting pressure on the dizzy cause its not correctly lined up. so basically the idler sprocket gear is sitting very slightly lower than it should be
awesome.
besides not being able to turn the dizzy by hand, is there anything that negative about this? besides more wear and tear from the extra pressure? cause i dont think i can fix this. maybe take a dremel to the inside of the front cover to free up some space for the dizzy?
