Magnum375 Jr. »
https://forums.nicoclub.com/magnum375-jr-u135673.html
Sat Mar 06, 2010 6:18 pm
You heard the man and saw the vid, Car is alive and healthy. Sadly I had no idea Tom was filming me, I was just excited that it wasnt leaking.
Started at 9:30am, and took me about an hour and half to pull the manifold and turbo with all the elbows on it. Longest thing was draining the fluids. So I didnt take any pics, of this progress. So I waited for Tom to arrive, I got a chance to take some decent pics of the crap that stopped me...Here is what it looked like, the banjo could easily move around, and not tight at all.
So I removed the fitting and the crap around the hole immediately showed me what happened. It wasnt JB weld, it crumbled under all the force of the banjo being cramped down. It fell apart as I took out the fitting.
Here's a huge chunk of it.
So I cleaned up the hole, used my knife and scraped it all out of the hole, so that the beveled edge was showing again. I then put the lines aluminum washer on it, with the beveled edge on it, and cranked her down tight. Tom and I reinstalled the manifold, with turbo and elbows on, no real issues, until we reinstalled the header nuts. Thats when I tightened the replaced non oem stud, and it just stripped itself out of the block, leaving no threads for the stud to stay in. So we took the stud and flipped it over, and i guess there were enough threads in the block that it worked...So I put the nut on, I need a big washer like stock, to make it work, its not holding anything atm. But car idles fine, no leaks. Keegan will give me hell, but whatever.
So we went out for a drive, I took Tom out the lake at Little Buffalo, showed him all the fun roads to drive out there, and we had a nice spirited drive. Took it easy for a little. I also want to say, I love this new steering wheel. It's amazing nice, and comfortable. We also threw in the synchromesh fluid, and its amazing, going into the gears was never so amazing. So I gotta admit this car is dailyable and I will be taking it to school monday.
