Hey what does your type r bov sound like. There are a couple of us on here that are curious to see if it really sounds like it is surging. My car sounds like it is suring but im not sure. It worked fine on my stock turbo but when i upgraded to a 60-1 all i hear is surging.Cjmartz2k wrote:
I think your engine bay looks good enough as is. It'd be different if it were dirty as hell or mismatching colors, but at least it's clean.Darius wrote:That was my only option. Couldn't fit the BOV on the hot side let alone recirc plumbing for it, and didn't want to spend another $45 on a stupid silicone bend to make it run in front of the CAS.
I don't really mind the way it looks and it is out of the way of the oil cap and everything else, so I think I can live with it until I decide to go MAP. Plus it keeps my oil catch line company.
Stupid clean, jeez that looks awesome!!rb26tommy wrote:
it hurts my head reading that. woow...what happen to grammar nowadays.sevenpt62 wrote:hey my bad sent you wrong email addy. its [email protected] again looking forward to you write up
thanks! iirc its 17x9 +26 all the way around. Need a slight pull/roll in the rear to fit my 275 DRs, but they look sick otherwise! That rear camber does need some work, lol been trying to get it all buttoned up before I start w/ new projects.Cjmartz2k wrote:Those Cobra rims look awesome. What's the backspacing on them? You need to adjust you camber hard core too.
why is your turbo blanket covering the compressor side of your "master power" turbo???Largekid wrote:here is some updated sexyness for you ladies...on the ign system, i'd have to look it up, but basically its just some MSD coils wired in sequence into the stock harness
+1gawdzilla wrote:why is your turbo blanket covering the compressor side of your "master power" turbo???
