R32 GTSTRB30DET rebuild with forged pistons, std rods, std crank, rb25det oil pump. 9:1 static comp. -R32 RB25DE head thats had a little work usual port polish valve deshroud and multi angle valve job. - Blocked rear oil restrictor and 1.5mm oil restrictor up frontGT3076r .6 Port Shroud Comp .82 (HKS3037S spec) with Garrets internal gate housing on the std exh manifoldAdapted a GTR PFCStock air box with 100mm cai in to the inner bumperRB25DET GearboxNismo LSDTein HR set to 360mm std look ride heightToyo 225/50 16's that hold 360rwhp (DD Dyno Shoot6f) @ 15psi without issues.
Its currently sitting in the drive way waiting for a set of cams to be delivered 264/264 9mm lift. 221 @ 0.050" and on to 400-430rwhp.
I will then try to squeeze it a little more with a water/meth injection kit for 450-460rwhp. Realistically the turbo is pretty much maxed out at 450rwhp and the std exh. manifold around 300rwkw (400rwhp). Time will tell.
Wish I went the GT35r now and could have squeezed 390rwkw (522rwhp).See how the little GT30 goes first.
The idea was to build up a no lag stock looker which it has turned out to be.
Modified by Cubes at 9:41 AM 6/29/2008
