ka24de vs. ka24det - Round II
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Yeah, injectors should test b/t 10-14 ohms. I need to pull the ECU and see if there are any codes before going any further. Thanks for the help guys.
Kckouki
Car: '97 Nissan 240SX
Got these back :p
homeslicej2
Back? You sold them originally? I still haven't posted pics of my new wheels have I? I need to do that.
Kckouki
Yeah I was a retard and sold them right before i sold my grey kouki.
Chris28
Car: 92 s13 KA-T
Boost is so much fun! Just got my turbo setup back on, spools so much faster with the rebuilt turbo!
Razi
Car: Moo
Haha.
Boost ftw!
After I set my timing properly, I've been going into boost more often.
The gas station is getting money more often now. :(
Chris28
Car: 92 s13 KA-T
Aight, here's a new problem. I just tried hooking up my PS cooler that has been sitting on my car for a while, and some weird things happened. First, once I refilled everything with PS fluid, I had no power steering at idle but crazy power steering while cruising, like any bump in the road would throw the steering wheel in that direction. I took everything off so it would go back to normal, and now I have no PS at all. The pump isn't making any noise, it's like there's a clog somewhere in my PS system. It's possible that there was water in the cooler and now I have a bunch of water in my system, but would that make it not work at all? Any thought on what else it could be? I might even make a new thread since I really want my power steering back haha.
Razi
Car: Moo
Did you bleed the power steering fluid after you did all that?
Chris28
Car: 92 s13 KA-T
I'm sure there was air in it after hooking up the cooler, but I went from lock to lock a few times as well as drove around the block, it didn't get any better.
Since putting it back to normal and bleeding it I have absolutely no power steering, it actually feels harder to turn than not having power steering normally feels, so I think there might be something blocking the lines somewhere, possibly water. I think once I get home for Spring Break tomorrow I'll jack the car up and take off the lowest PS hose from the rack and start the car and let everything pump out of the system, then put another pump on.
Razi
Car: Moo
Weird.
Yeah I guess something is blocking the lines since PS systems aren't all that hard to bleed.
WDRacing
When you lose ps, your fighting against a sealed system when you manually turn the wheel, that's why it's so hard. If the lines were routed differently it would be much easier...not that you want to, just sayin.
Chris28
Car: 92 s13 KA-T
Yeah, I thought about just looping the lines but I really enjoy having power steering haha.
I just looked through my garage and found 2 spare pumps, one of which I know is bad so I have a 50/50 chance of putting the good one on lol.
adrianfromthecastle
Car: 1992 Nissan 240sx
ugh... since we're on the subject of PS... my PS pully doesn't want to move. I can just take the belt off and drive it right? LOL
Razi
Car: Moo
:rotfl
motoman399
Car: 98' wrecked (RHD coming soon) 240
hi guys... its been like a month since i have been on here.. sucks not having internet at my apartment.. miss you guys lol :sad:
Razi
Car: Moo
Hello! :D
Chris28
Car: 92 s13 KA-T
Draining the fluid and re-filling the system somehow magically brought the pump back to life...score!
Hey moto! Long time no chat haha.
homeslicej2
Probably had air in it then. 3rd shift sucks. My sleep schedule has gotten completely out of whack in the last 3 months.
spooled240
Car: kouki s14
i need to flush my ps, how did you drain it chris?
Chris28
Car: 92 s13 KA-T
Turns out draining and re-filling only worked temporarily. When I installed the new pump I just disconnected the return line from the reservoir and turned the engine over a few times (no fuel/spark) so the pump would pump everything out.
I finally got my wrecked shell out of my garage, it was sad seeing it in the crusher :(
biggie
Uhm, maybe someone in a pink hard hat should have hidden when the camera came out. :)
spooled240
Car: kouki s14
homeslicej2
At least you were able to sell/use a lot of the parts so only the shell was crushed, still sucks to see a car crushed :/ I guess your PS pump is bad then. Is it whining any? If not, it could be the rack. I went to Atlanta today and even with the driver's window down almost the entire time, I got 28mpg. I'm 21 mpg around town, so 21/28 and the car is running a bit rich even though the FPR is set at 36psi (with vacuum hooked up), so I know it's not the injectors dumping too much fuel. Wonder what mpg I'd get with the window up and a tune? I have checked so far this week, and they all tested good: Coolant temp sensor, O2 sensor, injectors, coilpacks, spark plugs (pulled them and they looked good, gapped correctly) MAF, and TPS. Haven't checked the timing since last fall (need to rent timing light again, but was dead on ~3000miles ago) I'm beginning to wonder if it's the fuel pump, turbo, or wastegate.
Kckouki
Cant wait till sunday!
Razi
Car: Moo
homeslicej2 wrote:At least you were able to sell/use a lot of the parts so only the shell was crushed, still sucks to see a car crushed :/ I guess your PS pump is bad then. Is it whining any? If not, it could be the rack. I went to Atlanta today and even with the driver's window down almost the entire time, I got 28mpg. I'm 21 mpg around town, so 21/28 and the car is running a bit rich even though the FPR is set at 36psi (with vacuum hooked up), so I know it's not the injectors dumping too much fuel. Wonder what mpg I'd get with the window up and a tune? I have checked so far this week, and they all tested good: Coolant temp sensor, O2 sensor, injectors, coilpacks, spark plugs (pulled them and they looked good, gapped correctly) MAF, and TPS. Haven't checked the timing since last fall (need to rent timing light again, but was dead on ~3000miles ago) I'm beginning to wonder if it's the fuel pump, turbo, or wastegate.
How long has it been since you changed the fuel filter?
Our Q45 was acting super sluggish and it turned out to be the fuel filter.
homeslicej2
Less than 3000miles ago Razi. I changed a lot of stuff last summer/fall. It's an OEM Z32 fuel filter too. Jeez Casey, is that a stretch or what? A 205 on a what, a 9 inch wheel?
Kckouki
Yessssir. Not to much of a strech buts its nice.
Chris28
Car: 92 s13 KA-T
Biggie: Haha the scrapyard only had pink hardhats!
Homeslice: I replaced the pump but it's still acting up. If I don't use PS for a while (highway driving or if the car is parked) then I have it for a few turns and it's gone. I'm betting there's still water in there and it's causing weird things to happen. Pump doesn't whine at all though which is weird.
Do you have a consult cable? Maybe you could datalog some stuff to see if anything is acting up.
Erryone else: I got 2 tickets in one stop today, first one was for being too low and the second one was for exhaust. First time in 3 years I've ever had a problem.
WDRacing
Kckouki wrote:Yessssir. Not to much of a strech buts its nice.
Am I really the only person who thinks that is awful looking, not to mention dangerous?
Kckouki
Okay, a 205 on a 9 is not a big stretch at all, people do WAY stupider stretches then that. Plus itll help my little KA sping em.
