FSUDrifter's Project SR Build/Question Thread
FSUDrifter
Car: trying to decide on one...
I had to send my laptop off for repairs, so I haven't been able to update with pics.
The car is done with everything, mechanically. Right now it's at a local performance shop getting checked out. I just wanted to make sure everything looked good before I started driving it because this was my first turbo build.
I'll try to get some pics up soon.
Geno750
I was at the shop today to get some pigtails for my corner lights and to see if they had an anchor for a gas tank strap. I saw a car that looked very familiar, but I didn't get a chance to confirm that it is yours. BTW, those rims look great, and if your going with silver for the outside of the car like you did the engine bay, the car will be bad a**.
As for my project, I am waiting on an anchor for a gas tank strap(thought I had two, but turns out I only have one), and some SS hose since the hard line for the water feed won't fit, and neither will the oil return. The center housing on my 2560r isn't clocked like the regular s15 turbo. On the plus side, those are the only things left to do to get my car up and running. I'm undecided if I just wanna stick the engine in now or wait till I get those lines in.
Modified by Geno750 at 3:11 AM 1/13/2007
Modified by Geno750 at 3:13 AM 1/13/2007
Modified by Geno750 at 8:55 AM 1/27/2007
otterman
FSUDrifter wrote:
Well I was told that you can't use SAFC with 740's and I'm not really lookin to make any more than 350 right now.
I thought it was that the SAFC can't do over 50% fuel adjustment. 50% of 370 is 185, so the SAFC maxes around 555. If the 50% fuel adjustment is true and you're ecu is tunned for 550s, cant you use SAFC to bump to 825 (if you really wanted to). (550 * .50 = 275 275 + 550 = 825)
FSUDrifter
yeah that makes sense. Idk, I want to rebuild the head before I put 740's on, that would include new cams, springs, valves, retainers, greddy im, etc. So if I get tired of this amount of power I'll send the injectors back to DW for the upgrade. thanks for the info.
Some pics:
wheels mounted
90% done
needs some work
Deadrodent
Car: 1992 240sx hatchback
hey fsu, how was the dash install? I have a small crack and access to a new dash - just wondering how easy it is to accomplish, especially without destroying the new dash...
and by the way, what kind of gauge cluster is that?
mrzabala
Car: 93 Nissan 240SX SE Hatch
If you want, I can install your dash for you for a small fee. Its not hard at all when you been doing it so many times.
And FSU, do you have any pictures of the engine out ready to go into the engine bay on every angle?
FSUDrifter
Deadrodent wrote:hey fsu, how was the dash install? I have a small crack and access to a new dash - just wondering how easy it is to accomplish, especially without destroying the new dash...
Actually, I didn't install a new dash... I just meant I chose that cluster to cover up the crack. The cluster is an Autometer WRX STI pod. It doesn't fit perfectly to the contour of the dash, but it looks good enough for me.
Installing a new dash isn't hard. It just takes a while. Just don't lose and screws and don't forget to plug all the wiring back in and make sure the vents are lined up right. Oh yeah be careful not to crack teh defroter vents, they are pretty brittly from being in the sun and crack easy.
mrzabala wrote:And FSU, do you have any pictures of the engine out ready to go into the engine bay on every angle?
I have a couple. What do yuo need to see specifically? I have a ton of pics saved of other sr's.
nonvtecaccord
so how does it run? I noticed that your MAF is still close to your turbo.
FSUDrifter
nonvtecaccord wrote:so how does it run? I noticed that your MAF is still close to your turbo.
runs good, just gettin checked out.
there is a 9" piece of 3" exhaust in there, you just can't see it. that def made a huge difference though
mrzabala
FSUDrifter wrote:I have a couple. What do yuo need to see specifically? I have a ton of pics saved of other sr's.
Probably the most I need to see is a straight shot on the side where the turbo is and also on the other side. I have to re- clock my turbo compressor. Basically I have all the stock sr parts except for ps bracket, piping, and hoses - just to give you an idea of what Im working with. The more pictures the better it will help me get mine in the car. Thanks.
sup4fr34k
Car: 2000 Eclipse GT, 1990 240SX, 1990 Camaro
what offset are those wheels? and size? Do you have spacers?
FSUDrifter
sup4fr34k wrote:what offset are those wheels? and size? Do you have spacers?
17x9 sportmax 962, +35 all around, 5mm spacers in front, no spacers in back. 235-40's front, 255-45's back. stock suspension, stock brakes.
Car is almost done. I found out my Z32 MAF was bad. Soooo close....
jubee
Car: 92hs13
car is comming along nicely man post some pics up . you will love the 2871r its was a blast on my car. only diffrence i had the .86 i fell its much better then the .63. also i would def invest in some cams just to wake that turbo up even more.
BTW what shop has your car? xat, DC???
FSUDrifter
jubee wrote:car is comming along nicely man post some pics up . you will love the 2871r its was a blast on my car. only diffrence i had the .86 i fell its much better then the .63. also i would def invest in some cams just to wake that turbo up even more.
thanks, we'll see about the cams. I want to see how fast the car is going to be like this. Like I said before, this is my first turbo car. I'd prefer not saying what shop the car is at until I get it back. I'm getting really paranoid about my car getting stolen having posted all this up on here. At least I'm the only one who knows about all the theft prevention stuff done to the car...
Geno750
Did they call and tell you that? Last night I loaned them my z32 maf to see if that was the problem.
Modified by Geno750 at 9:40 AM 1/28/2007
luv2spedup
Car: 89 silvia
dude i ordered the same wheels for my car can you please post some pics of the car with the wheels and tires mounted im going loco to see how they look and yes sweet setup, enjoy your car man
mrzabala
FSUDrifter wrote:thanks, we'll see about the cams. I want to see how fast the car is going to be like this. Like I said before, this is my first turbo car. I'd prefer not saying what shop the car is at until I get it back. I'm getting really paranoid about my car getting stolen having posted all this up on here. At least I'm the only one who knows about all the theft prevention stuff done to the car...
Yeah Im with you on that FSU. I deleted all most post and pictures of my car a week ago. Even though I doubt someone can steal my car without getting caught, you can never be too safe.5
mrzabala
Change your sig. The picture is stupid and does not need to be oversized. Read the rules and abid to them.
luv2spedup
Car: 89 silvia
mrzabala wrote:Change your sig. The picture is stupid and does not need to be oversized. Read the rules and abid to them.
dude are you for real, u need to grow up im not the one with some silly animation for my signature, and secondly mind your own f***ing buisness im not talking to you
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
dude.......you are completely out of your league it seems.
1. That animation on your sig has nothing to do with nico, cars, or this forum.
2. Why must you be so quick to jump down his throat about asking an innocent question.
3. People like you make forums threads go sour. Please say what you mean and dont say it mean.
4. If you want to be a SIG PIG then become an admin and then well see whats up.
5. For now.......PISS OFF
cheers!
mrzabala
oops I forgot to put big after stupid. I kind of dont regret it now since you made fun of my sig. Its not like your smile has anything to do with nico. Gtfo and Get over yourself.
luv2spedup: You too. Do you need to talk to me so that I can talk to you? Lol gtfo too and get over yourself.
Lol checked out your little car domain. Nice list: is that suppose to be a check off list when people jack stuff from your car? Sigh. Kids this days.
FSUDrifter
Please stop jacking my thread. Take it somewhere else.
I'm not a moderator but sig rules are there for a reason, it would be nice if you would respect the NICO community and follow the rules:
Sig Rules
UPDATE:
I went to pick the car up yesterday, but it was still misfiring a little at higher rpm's under load, so hopefully they can figure it out be next weekend.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
dude your on an internet forum, your talking to everyone and everyone is talking to you.
fsu: you have a good build going on. g/l with the missfiring hopfuly my motor gets here tomorow
Geno750
FSUDrifter wrote:Please stop jacking my thread. Take it somewhere else.
Sig Rules
UPDATE:
That sucks, I'm willing to bet that the bad maf fouled your plugs. I installed the engine in my car today, and the new flywheel bolts will be here tomorrow so hopefully I'll be finished this weekend.
FSUDrifter
Geno750 wrote:That sucks, I'm willing to bet that the bad maf fouled your plugs. I installed the engine in my car today, and the new flywheel bolts will be here tomorrow so hopefully I'll be finished this weekend.
Actually he changed the plugs, but I don't know if that was before or after he put your MAF on.
btw your maf is still there, I'll probably be back next weekend and I can get it for you, if not I can get someone to take it to your house or something. I'm getting a reman one but it takes like a week to get it.
Geno750
Don't worry about it, the guys at the shop know we know each other. Today they let me go over to your car and look at the boost lines so I could make sure I got them right on my car (I did). I got the dodge omni flywheel bolts to replace the 3 necked ones. Well 4 actually since I have to keep the thing balanced, so I should have the car together tonight or tomorrow.
FSUDrifter
Thanks for all the help.
UPDATE:
The problem was the BOV. I ran the car with a R2D2 BOV and it ran way better. It's pretty fast. I'm ordering the 11psi spring from Tial, and hopefully that will clear up the stuttering issues.
I need softer mounts, anyone ever try these?
MOUNTS LINK
Geno750
FSUDrifter wrote:Thanks for all the help.
UPDATE:
MOUNTS LINK
No problem man, I am glad I my parts were able to help you, and I got to make sure they work :D
After riding in your car I really want to finish mine now, damn work. Just 5 things left to do to make it run.
travisn
UPDATE:
MOUNTS LINK
yo 70 bucks for those is BS... there was a thread someplace around here that showed how to make those for like 15 bucks... all it is is some epoxy resin polyethylene **** and some threaded rod...
FSUDrifter
Greg said those mounts he made cost $56. I ordered them. $70 is worth the time it would take me to make those and the peace of mind knowing they should be reliable coming from a real manufacturer. I'll do a review when I install them.
Modified by FSUDrifter at 8:54 PM 2/5/2007
