FSUDrifter's Project SR Build/Question Thread
FSUDrifter
Car: trying to decide on one...
i've heard they can break off and ruin your turbo and engine. i think i'm going to do a custom remote mount for the oil pressure, oil temp, and idiot light.
tiger
first off, I think my oil temp probe is 1/8 NP (is that NPT or just NP?) I don't feel like spending 30 bucks on a sandwich plate. I'd rather buy some fittings and do it that way, how are you planning to customize yours?
Geno750
Like FSU said, the easy way is to remote mount the sensor. I just ordered a bspt fitting so I could use npt fittings and remote mount the gauge's sending unit.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Using the sandwich adapter was pretty easy IMO. Just getting to the filter was the hard part.
FSUDrifter
Pics of everything I ordered:
FSUDrifter
I made a thread about how I'm probably going to mount my gauge sending units. You can see it here.
Latest purchases:- power steering- air conditioning
redtop91
Did you end up going with the sandwich adapter? How hard was it (and the filter after) to tuck under the manifold?
FSUDrifter
FSUDrifter wrote:I made a thread about how I'm probably going to mount my gauge sending units. You can see it here.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Hey FSU, was wondering where you get your bango bolt that bolts into the block for the turbo oil line (below the water line, next to the motor mount)? Anyways, hows the engine? I see you bought a new front cover.
FSUDrifter
mrzabala wrote:Hey FSU, was wondering where you get your bango bolt that bolts into the block for the turbo oil line (below the water line, next to the motor mount)? Anyways, hows the engine? I see you bought a new front cover.
The banjo bolt came with the taka lines. The engine is good, just the leak coming from that crap oil pump/front cover and a tiny leak coming from the upper water neck. I'm pulling the engine again in a couple weeks to change out the front cover, change the mounts, and get all my gauge stuff installed. Then, when all that stuff is done... paint.
FSUDrifter
Thread about the hood: zerothread?id=244164
goj_cloud
hey fsu i wnated to ask u a question about ur aem tru boost u said u were bosting at 19 psi can u tell me what ur duty cyle and ur crack pressure is
FSUDrifter
goj_cloud wrote:hey fsu i wnated to ask u a question about ur aem tru boost u said u were bosting at 19 psi can u tell me what ur duty cyle and ur crack pressure is
- The guy at enthalpy told me I would be safe with 555's at 19psi as long as I'm on 93 octane. I just leave my BC set at 19psi all the time and never floor it so I don't boost that much unless I really want to.- duty cycle is determined by my chipped ECU, done by enthalpy. - Crack pressure? not sure what you mean by that...?
goj_cloud
u have the aem tru boost right? im basically asking what your setting are on the bc cuz i have one and its kinda complicated
FSUDrifter
yeah i have the truboost. basically since there are only 2 buttons you have to navigate the menu by either pressing one button, pressing both, or holding either combination of them. There should be instructions in the box, just follow the little tree.
Off the top of my head, while it's on, hold both buttons for like 5 seconds and then hit the left one for Prg A or right for B, then press left for up and right for down to set the boost limit.
goj_cloud
im trying to ask you what your settings for yours are
what is the duty cycle set to on the boost controller and whats your spr pressure set to on the controller.
hit me up on aim cloud3648 if oyu dont understand what im saying
FSUDrifter
I'm not sure, I'll take a look when I get a chance and let you know.
goj_cloud
but u know what im talking about right?
FSUDrifter
mrzabala wrote:Cant you use this? I installed my autometer oil temp with the fitting provided. I already installed the fitting and all it needs is the sensor so I plugged it up for now.
You installed yours in there or where the idiot light is? What is the thread pitch of that thing? What is that?
mrzabala
FSUDrifter wrote:You installed yours in there or where the idiot light is? What is the thread pitch of that thing? What is that?
I installed it where that big plug is on top of what I believe is the oil temp sensor (I forget so not 100% sure). The plug had a spring underneath, I have no idea what it is. This is one of those things that I NEEDED AN S13 SR FSM BECAUSE THERE NOT THE ****ING COMPLETELY THE SAME THING AS AN S14 (I made a thread asking for it and you guys were giving me ****- bastards).......I have no idea what the pitch was, sorry. All I know is that the ultra lite autometer oil temp sensor and the provided fitting fit, with the washer that was already there and a rubber washer, worked and I was able to torque it down..
FSUDrifter
that sounds kinda shady taking that thing out if it has a spring on it. I'm sure the spring was there for something... maybe. But, then again, if it's not causing any problems then who cares?
tiger
I have a defi oil temp gauge and I wish I knew where I could install it before I drop this thing in... there's a nismo oil tee on courtesyparts.com ...not sure if I could use that... says it's for oil press.
http://www.courtesyparts.com/M...3-GTA
Or I could just undo the pressure sender and screw in the defi temp sensor, imma go try that.. i'll tell you what happens... brb
Modified by tiger at 3:47 PM 4/27/2007
tiger
I just took of the sender thing and tried to put my oil temp in... the probe part was hitting that spring thing so I took that bolt off and took the spring with it.. now the defi temp probe fits right in... SO, will this cause any complications now that I have taken the spring out.. what is the spring's use anyway???
FSUDrifter
I'm not sure, maybe someone should make a thread asking what that is. I couldn't find it in the FSM.
tiger
hmm, well I got my temp sensor in the oil sender port.. sweet. Whats the most a spring could do? I felt down int here with my finger and didn't really feel anything strange.. just the walls of the ... whatever it is... plate?
FSUDrifter
I decided to just weld a bung in the oil pan for the oil temp and i'm remote mounting the pressure sending unit to the strut tower using stainless line.
FSUDrifter
test fitting my bumper and skirts. bumper fits like **** and skirts don't match:
should look good with some more aggressive skirts and the bumper worked on + paint...
engine is pulled to replace timing cover and clean some things up, should be back in soon.
this happened: zerothread?id=247443
kornaz
Car: 95 240sx SE.
Build coming along nicely. Long time ago i checked out S13 with sr20 swap done like ****. Wiring not done, mist parts taken off, and the guy he drove it. Didn't have the money, but could've bought it for about $2500. Had apexi exhaust and fn's on it. :|
I feel ya when you dig deeper and find more crap undone or done poorly, but you came a long way already. Keep it up!
goj_cloud
hey fsu r u still gonna tell me ur aem tru boost configurations
mrzabala
Man Pulling the engine and putting back in. Hows the coolant and oil? Spill? Re-use? Try and keep as much as you can? Hopefully you'll get the rear main seal retainer. How did it crack btw? Too much torque? BTW, I been meaning to ask but hows the setup with your maf being close to your manifold and turbo? I may have to do that since I cant find the stock pipe for sale. Thanks for any info.
