are those voltages on the MAF ok?FSUDrifter wrote:1) I had my ECU tuned for 19psi, should I go ahead and set my BC to 19psi even though it's running so bad?3) What should my vacuum reading be at idle? The interior electronics also don't work when I start the car unless I rev it up then they come on and everything works perfectly.
Checked:- MAF power = 10v, MAF signal = 1.1v
I don't think I got it man. I'll check again in the garage and see if my dad hid it somewhere.S13240 wrote:Did I send the right plug?
Yeah I'll probably do the heat wrap when I pull the engine.mrzabala wrote:Nice build up. Are you going to heat wrap your exhuast manifold? What kind of BOV is that in one of the pictures?
Well I'm certainly no expert, but I have no prob with you taking a look at my car.Geno750 wrote:This may seem strange but I just started building up a 180sx in Niceville and if your going to be in Destin this weekend I was wondering if I could take a look at your car to see if it can't help answer some of the questions I've been trying to figure out with my car.
Thanks, and if you need a hand with something I'm in town every weekend. I'm mainly curious about cosmetic things, everything else is backwards for my car since it is rhd.FSUDrifter wrote:Well I'm certainly no expert, but I have no prob with you taking a look at my car.
I'll send you an email.
