FSUDrifter's Project SR Build/Question Thread
FSUDrifter
Car: trying to decide on one...
kornaz wrote:Build coming along nicely. Long time ago i checked out S13 with sr20 swap done like ****. Wiring not done, mist parts taken off, and the guy he drove it. Didn't have the money, but could've bought it for about $2500. Had apexi exhaust and fn's on it. :|
I feel ya when you dig deeper and find more crap undone or done poorly, but you came a long way already. Keep it up!
Thanks man. that s13 soundsl like mine lol. It's coming together, once I clear this engine stuff up and get it back in I should be completely done with the engine stuff then can move on to exterior and interior projects.
goj_cloud wrote:hey fsu r u still gonna tell me ur aem tru boost configurations
I set it a long time ago and don't really remember. now the engine is out and gauge isn't hooked up because I'm moving it above the steering column. When I finish all that I'll let you know. AEM has forums with a lot of information, I would post up there and ask what to do. I may do that as well because I'm not even sure I had it set right.
mrzabala wrote:Man Pulling the engine and putting back in. Hows the coolant and oil? Spill? Re-use? Try and keep as much as you can? Hopefully you'll get the rear main seal retainer. How did it crack btw? Too much torque? BTW, I been meaning to ask but hows the setup with your maf being close to your manifold and turbo? I may have to do that since I cant find the stock pipe for sale. Thanks for any info.
I just drain the coolant into a drain pan and reuse it. The oil neede to be changed so new oil is going in. I cracked it by trying to take the upper oil pan off without taking the nuts off of those 2 studs on teh bottom of the retainer. It was dark and I didn't see them in there. I guess that's kind of a common thing after talking to a lot of people about it. My maf isn't there anymore, when I was getting diagnostics done a local shop put a pipe on there. I would reccommend going to an exhaust shop and just get them to bend you a custom pipe, shouldn't cost more than $20-30. I atually have the stock intake if you are interested.
Tsukiko
Car: 1990 240sx fastback KA24E
hey i was wondering what happened to the K-sport coils i saw earlier in the thread. did you ever install them, and how did you like them? ive only read one review on them, and the guy was pretty harsh about it.
FSUDrifter
Tsukiko wrote:hey i was wondering what happened to the K-sport coils i saw earlier in the thread. did you ever install them, and how did you like them? ive only read one review on them, and the guy was pretty harsh about it.
Oh yeah i ended up canceling my order because Intensepower was taking like 3 months to ship them.
I bought some used ksports off here a long time ago for my last 240 and they were alright. The design was nice, the threads should have been teflon coated so they didn't get corroded though. The ride was pretty bumpy but I got used to it quick.
boost_creep
Car: 92 sr powered coupe,06 Spec V
are you running spacers with those wheels?if so, what size?
FSUDrifter
boost_creep wrote:are you running spacers with those wheels?if so, what size?
5mm frontnone rear
stock brakes, suspension just has lowering springs
I have 15mm's to put on the rear once my body kit goes on.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Did you install an oil pressure gauge? If so how did you contort yourself to reach the idiot light pressure sensor?
boost_creep
whats the offset for the wheels.they are 17x9 right?is the offset +35?wouldnt the spacer up front make the wheels stick out more than the back.please enlighten.thanks.
FSUDrifter
redtop91 wrote:Did you install an oil pressure gauge? If so how did you contort yourself to reach the idiot light pressure sensor?
yes, I had the engine out lol.
boost_creep wrote:whats the offset for the wheels.they are 17x9 right?is the offset +35?wouldnt the spacer up front make the wheels stick out more than the back.please enlighten.thanks.
yeah they are 17x9 +35 all around. Yes the fronts probably stick out a little more than the rears but it isn't noticable. I'm going to put the spacers on the rear, I've just been lazy. I have to cut the studs because the wheels are universal and there is no room for the hub studs to go into the back of the wheel. Here is a thread explaining what I'm talking about.
redtop91
Damnit. NOT the answer I was hoping for. LOL. Oh well.
boost_creep
cool,thanks alot man.so when i get the spacers i should get shorter studs too.are you happy with your spacer size?hows flushness?
