FSUDrifter's Project SR Build/Question Thread
Wulfpak
Car: 1990 240sx
Hey FSU,What size wheels did you put on there and did you get spacers for them?
Thanks,Moe
FSUDrifter
Car: trying to decide on one...
Wulfpak wrote:Hey FSU,What size wheels did you put on there and did you get spacers for them?
Thanks,Moe
FSUDrifter wrote:
17x9 sportmax 962, +35 all around, 5mm spacers in front, no spacers in back. 235-40's front, 255-45's back. stock suspension, stock brakes.
spacers from egay, universal 4 lug like $10 or something. probably will vibrate at high speeds because they are not hubcentric. I'm just using them temporarily until I get a real suspension setup because everything changes with coilovers.
FSUDrifter
ORDERED: - New 11psi spring for TiAL BOV - Quicktap for boost signal closer to the turbo
karmakaze
Car: 98 240sx SE
FSUDrifter wrote:ORDERED: - New 11psi spring for TiAL BOV - Quicktap for boost signal closer to the turbo
I never liked the look of those things. why not just buy a 1/8npt tape, a drillbit, and a 1/8npt barb fitting? probably would of cost less and looked better.
FratGuyBelushi
Car: Still searching...
Wow FSUDrifter, this is a great build. Please keep us updated!
brandonb012
Car: 91 240sx
nice build its coming along good!!!
BTW dont use those mounts just spend more money and get the nismo mounts, my buddy has those on his 240...well they stayed on for about 15 he said they sucked
FSUDrifter
Quote »BTW dont use those mounts just spend more money and get the nismo mounts, my buddy has those on his 240...well they stayed on for about 15 he said they sucked[/quote]stayed on for about 15? 15 minutes? because they came off? or he took them off?
i already ordered them, i don't understand what you're saying, please clarify
mrzabala
Car: 93 Nissan 240SX SE Hatch
Hey Josh, was wondering, how did you take off your front cover/oilpump? I didnt want to rish breaking off a piece since theres groovers for my flat head screw driver to fit and hammer. Its really tough and I can get anything slim enough to slide and start prying. I got my crank pulley off and replaced my front seal. I probably wont take it off unless I replace the seal again so just wondering how you did it? Btw, hows the progress so far on your car?
FSUDrifter
mrzabala wrote:Hey Josh, was wondering, how did you take off your front cover/oilpump? I didnt want to rish breaking off a piece since theres groovers for my flat head screw driver to fit and hammer. Its really tough and I can get anything slim enough to slide and start prying. I got my crank pulley off and replaced my front seal. I probably wont take it off unless I replace the seal again so just wondering how you did it? Btw, hows the progress so far on your car?
Make sure you have all the bolts. You have to take the valve cover off to get to the 2 that are inside the head. You also have to remove the CAS to get to one of them. And, you have to take off the upper and lower oil pan to get to those bolts.
My car should be done, mechanically, whenever I get the new spring for my BOV in. If that fixes the BOV of course. Then I'm moving on to exterior stuff, lowering springs, front body kit, new hood, sideskirts, paint, tint. I'm also gonna build a custom box for my sub and amp I think.
My parts should be coming in sometime next week, hopefully.
brandonb012
Car: 91 240sx
they didnt come off, he took them off after driving the car for 15 he said they vibrated like crazy and didnt feal good to him at all..
id still try them since you already ordered them, but after you get them installed give me your impressions of the mounts, he might have just got a bad set!!
corey240
Car: 1993 Nissan 240SX Base Drift Machine
brandonb012 wrote:they didnt come off, he took them off after driving the car for 15 he said they vibrated like crazy and didnt feal good to him at all..
well thats kind the point, correct me if im wrong...they are stiff so the motor is more "firm" on acceleration, kinda like the same point of an engine tourque dampener.
karmakaze
Car: 98 240sx SE
corey240 wrote:well thats kind the point, correct me if im wrong...they are stiff so the motor is more "firm" on acceleration, kinda like the same point of an engine tourque dampener.
correct, with a firm or solid mount a good bit of vibration is normal.
FSUDrifter
I'm getting them because I have solid aluminum mounts now, and I can't deal with them since my car is a daily driver. I can't even talk on my cell phone they are so loud. Maybe these won't be much better, if they are still too firm, I'll sell them and get nismos's. I had nismo's on my built SOHC in my 2nd 240 and they didn't vibrate much at all.
nonvtecaccord
I've heard of people complaining about their nismos being to hard for DD. I ordered all new oem mounts.
nonvtecaccord
looks like it will leak to me but I could be wrong.
FSUDrifter
nonvtecaccord wrote: looks like it will leak to me but I could be wrong.
I know people that have them and they work great.
karmakaze
Car: 98 240sx SE
nonvtecaccord wrote:I've heard of people complaining about their nismos being to hard for DD. I ordered all new oem mounts.
I have nismo mounts that i reinforced with liquidnails. i have not driven on them though. I do not care about the noise or vibration though. I kind of like the idea of being able to get female passengers off.
nonvtecaccord
karmakaze wrote:I kind of like the idea of being able to get female passengers off.
a coment like that = "I've never had a "real" girl friend before." LOL, I'm kidding, I'm kidding but seriously A friend of mine has Energy Suspension motor mounts (the red ones) in his dsm (yes I know its a dsm) and they vibrate so much I don't like to ride with him, it gives me a headache. They are so stiff his dashboard moves up and down when he shifts hard.
nonvtecaccord
Yeah, now that I think of it, if its tight enough it should seal properly. But it seems like a quick fix vs. a actual nipple in a hard pipe.
Geno750
Having ridden in the car, I can tell you its not like the back seat on a Harley Davidson. The dash rattles so loud you can't hear the exhaust. FSU and I had to shout to each other so we could carry on a conversation, definitely too loud for a DD.
FSUDrifter
Haven't been on here in a while.
I figured out at least one of the coilpacks was bad so I ordered 4 new from nissan. Also, installed a sheet-metal splash gaurd/skid plate. I got a new hood.
Now I'm ordering gauges and getting all of my body stuff planned and getting ready for paint.
a recent picture, (still ghetto)
and a video:http://www.youtube.com/watch?v=0AU7NGDVE7U
Geno750
Ah yes I-10 is fun, but 150mph on stock suspension must of been a little scary but I can't really say anything, I tested my TRE on the gixxer on I-10 by getting up to an indicated 186mph
nonvtecaccord
FSUDrifter wrote:and a video:http://www.youtube.com/watch?v=0AU7NGDVE7U
FSUDrifter
Geno750 wrote:Ah yes I-10 is fun, but 150mph on stock suspension must of been a little scary but I can't really say anything, I tested my TRE on the gixxer on I-10 by getting up to an indicated 186mph
i put used sportlines on some tokico blue's on the front and the rear shocks are blown, that should be adequate for those speeds... lol
Ordered:- New Oil Pump/Front cover (all that work I did to stop the leak didn't work)- New Coolant temp sensor (hopefully will clear up my high/rich idle thing)- Nismo mounts
If anyone needs a new oil pump I just got a brand new for cheap, just ask.
Modified by FSUDrifter at 10:25 AM 3/22/2007
Modified by FSUDrifter at 10:09 PM 3/22/2007
FSUDrifter
Ordered:- 180sx marker lights for my aero bumper- oem sideskirts- oil pressure, oil temp, and water temp gauges- ati steering column pod
I'm trying to figure out how to hook up my oil gauges, sandwich adapter seems like a good idea. I know this looks shady as crap, but what do you think about this thing? ebay adapter They said if I had any problems they would refund me but not shipping or restocking fee.
I know greddy makes one too but it's like $60.
Pics up later... 3 exams today
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
That one looks kinda shady. I have a Trust/Greddy one and it was worth the 70 bucks. It installed like a charm.
Geno750
FSUDrifter wrote:Ordered:- 180sx marker lights for my aero bumper- oem sideskirts- oil pressure, oil temp, and water temp gauges- ati steering column pod
http://www.splparts.com is where you want to go for the fitting for your oil pressure gauge, they sell the bspt fitting that will thread into where the stock sending unit goes. You can also get a t fitting that will let you use the stock sender as well as the the one for the gauge. I just ordered one, it was $15 shipped.
mrzabala
Cant you use this? I installed my autometer oil temp with the fitting provided. I already installed the fitting and all it needs is the sensor so I plugged it up for now.
redtop91
Yes actually you can but doesn't that remove the idiot light on the dash? Some motors throw codes when that is removed IIRC.
tiger
I have the Defi oil temp sensor, I guess I can use the same fitting for the pressure sensor and hook into the stock oil sender location? Is that good placement?
