Free Sleepy eye mod... quck and easy
kickertu
Not sure if this has been posted or not, but everyone i have talked to had to idea about it, so i thought i would contribute.
Parts needed:Wire CuttersBell cap (optional)
well this is actually a pretty easy trick. find the headlight button that makes the headlights come up and down without turning them on, and pull it out. you should just be able to wiggle it out, but it will come out.
locate the brown wire on the back of the button, and cut it. if you would like, you can put that bellcap on it, to make sure that it doesnt short to anything. then re-install the button by pushing it in.
after its re-installed, press the buttton in, and turn on the headlights, and then turn the headlights off. the headlights should stay up.
to get them to set where you want press the "modified" button in and out until it reaches wanted height. the button basically acts like a "hold" button for the headlights.. so when its pressed in it will hold them in place.. when its out, they will work like normal
thats it!!!have fun.. im me if you have questionsaim:kickertumsn:[email protected]
allthrottlenobottle
Car: 91 s13
when you turn the lights off the assemblies go down normally?Do you have to press the "modified" button in and out again to set them or will they return to your desired height? Good trick ! Thanks for the info!
kickertu
you will have to set it everytimne you turn on your headlights and then turn them off... but its hella easy to do
allthrottlenobottle
Car: 91 s13
thanks kickertu. I think I'll give it a try.
lbrowne
now this seems pretty easy.
but, if you want the lights to function normally without touching this button, do you just make sure you hold in the button till they go all the way down?
Will the system then stop once the lights are fully retracted or will the lights keep flipping up and down if you keep your finger in on the switch?
IvanS13
Car: *** & Titties
Werd life... I'll try that and I'll post up some pics for you guys when it is done.
S13HatchLuvr
Car: 1991 S13 Hatch (white) 5-speed
What's up everybody... I just wanted to let everyone know that my brother and I both did this quick modification on our 240's and IT WORKS WONDERFULLY... Plus you don't have to have a stupid-looking non-stock control switch to control the headlights! The headlights work normally when the button is not depressed. Give it a try! Cost: $0.00 (If you've already got a wire cutter and some electrical tape to wrap up the cut wire tips)
allthrottlenobottle
Car: 91 s13
I just completed this mod and it works well. I find it jars the lights pretty good but it's a good trick for at shows and such without having to adjust the lifting arm mechanisms every time you go from show to street. Good tips guys!:D
BB Turbo
Car: 2007 Nissan Titan KC
1992 Nissan 240SX Coupe
Just to make sure, and sorry for the post revival, but it does work nice? anyone else done it? Do you like it?
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
works ok, although on some, like mine, the motors won't stop at the same height so i have to manually adjust them anyway
BB Turbo
Yeah, while I was detailing the car today, my friend actually did it within a few minutes. I like the look, looks very clean :)
IlIkEmYz
Car: 06 Z
allthrottlenobottle wrote:I just completed this mod and it works well. I find it jars the lights pretty good but it's a good trick for at shows and such without having to adjust the lifting arm mechanisms every time you go from show to street. Good tips guys!:D
it also increase hp because with the light adjusted to the right angle the light would allow more into the intake.:ylsuper
BuLLeTdrift
Car: 91 240sx fast baq
i'm gonna try this first thing in the morning!
240dreams
Car: 240's
do the headlights stay in sleepy mode when the lights are turned on? i have setup (my avatar) but would rather use the stock buttons. i hate when ppl ask me "what are those for?"
marshun
007jpang wrote:it also increase hp because with the light adjusted to the right angle the light would allow more into the intake.:ylsuper
uhh...
andrave
Car: 1989 Nissan 240SX Coupe
damn your sig is freaky
marshun
so this is so the headlights dont retract then? but they do retract when you turn the headlights on and then off?
so when you just push the button, they go up but not down?
i think i'll pass on this one.
Tenmou
When you do this:
-You can't raise the headlights with the push button anymore, just the headlight switch
-When the headlights are raised up, you can press the push button repeatedly to make your headlights go down to where you want them.
Very similar to other methods seen here except it doesn't use anything that didn't come with your car. So, unless you want to keep the ability to raise your headlights without actually turning them on, it's worth a try. Hope this answers your question and feel free to correct anything I messed up on.
BuLLeTdrift
i just did it earlier today (like i said i was). your headlights will raise and lower like normal, but when the "modified" button is at work, it holds them in wut ever position you want. i think this was a kool *** idea/trick. as soon as my friend found out i could do this, he wanted me to do his. you have nothing to lose when you do this. unless you just like lifting up your headlights w/o having them on for no reason.
240dreams
Car: 240's
can you turn your light on when its half way up without the headlights automatically retracting?
Touchdown038
Car: Computers, cars, sports
Nope.
I"m kinda shying away from the lazy-eye look lately, because when I do it, I always get question from people like "what's wrong with your headlights?"
Supafly
240dreams wrote:can you turn your light on when its half way up without the headlights automatically retracting?
if you turn them on using this setup they will drop to the bottom then cycle to full open as normal.
marshun
BuLLeTdrift wrote:i just did it earlier today (like i said i was). your headlights will raise and lower like normal, but when the "modified" button is at work, it holds them in wut ever position you want. i think this was a kool *** idea/trick. as soon as my friend found out i could do this, he wanted me to do his. you have nothing to lose when you do this. unless you just like lifting up your headlights w/o having them on for no reason.
i see. so i'd have to turn on the headlights so that i can wash'em now eh? hehe. i'll give it a try today anyway :)
magus0216
very easy, thanks for the info.
IlIkEmYz
Car: 06 Z
i did the mod and it works!!
but the sleepy eyes are uneven.how can i make them even??
annunziato39
Car: 1990 240 (auto) sold 1992 240 260,000+ miles (rip) 1991 240 (sold) 2007 Infiniti G35 sport 6-speed (Current)
I just did the mod, literally 2 minutes. You get the lazy eye look and you don't give up any of the standard controls. Awesome DIY mod Kickertu.
scruffy63
Car: my nissan 240sx
good mod but for those of you who live in the colder regions, this might be a bad idea.the switch is there for a reason so you can have your lights up without them on. this is only needed when your lights get frozen and won't move(daytime of course.). just my .02
hey annunziato39 I'm from NY. too. i grew up in springvalley. do you know where that is.
annunziato39
Hey Scruffy I live in Nanuet. And Scruffy is right about the cold areas. It was a little cold this morning and the motors were a little slow to just pop the lights up and i had to warm the car up before they worked properly, still a good mod, just a little heads up for all you guys who see snow in March.
scruffy63
hey what school do or did you go to. I went to chestnut ridge junior high, my bro went to springvalley high.then we moved down here.
annunziato39
i graduated St. joes in montvale in 97 and i'm actually moving down south to NC in august. The cost of living up here is just to much.
