Free Sleepy eye mod... quck and easy
Goldeneagle
Car: 1992 240sx Coupe
themike wrote:Has anyone tried to disable the switch's "lock" feature? By this I mean make the switch so it never stays in the forward position. This way you can just push it to where you want it instead of double clicking it to the spot you want. Maybe a rotary switch to "dial" the lights to the right height?
$.02
mike
Pivot has a switch with a rotary dial which will stop the lights at a desired height.
Anyway...for the person who said HP is increased because more air is getting through the headlights...regardless of air flow going into the stock airbox, HP is not going to increase if you are using an OEM air filter. OEM air filters are made out of paper and only allow soo much air past them. Other things to take into concideration are the Mass Air Flow sensor, fuel injectors and the spark plugs.
1989nissan240sx
Car: 1989 nissan 240sx
hey i found this on youtube.com a while back...i tried it and it works great..and you can turn on your lights while sleepy eye...it is in a foreign languauge but you can tell what he is doing...take a look...cost only 10 bucks for the supply....<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/-IM3lPh4VKo"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/-IM3lPh4VKo" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
1989nissan240sx
1989nissan240sx wrote:hey i found this on youtube.com a while back...i tried it and it works great..and you can turn on your lights while sleepy eye...it is in a foreign languauge but you can tell what he is doing...take a look...cost only 10 bucks for the supply....<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/-IM3lPh4VKo"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/-IM3lPh4VKo" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
I tried to embed the video...but it didnt work so here is the link..take a look it is very easy...http://www.youtube.com/watch?v=-IM3lPh4VKo
catatonicpinoy
Car: 1990 Nissan 240sx SE Hatchback.. 5spd. and stock^^
im really tempted to go outside right now and "cut the brown wire".. but.. will the lights still be able to open all the way for night driving?
ZiG
Car: 1993 240sx coupe
You put your email address up? How many ricers do you get each week asking for tech support?
CynCityS13
Car: S13 Coupe
I tried it n it worked!..Thats a koo trick..thanks for the info.
benarovi561
Car: 92 black hatch
hahaha im 16 but i no like 5 times more than those dumbasses who r like yo jdmas f*** its got vtec meeen. lol
Harvey s13
Car: 1990 240sx hatch
ha it was real easy for me, i took the button out and the brown wire was already cut. lol
slagithor
Car: 1991 240sx
Thanks for the How-To!
