My MPG went the other way after the CVT replacement my City MPG went from 23-25 to 27-28mph, highway seems to be seaching the RPM mores so MPG went down 1MPGdaytrippr wrote:
PS, I noticed that since we got our CVT software fix, we get better mileage at highway speeds and worse around town.
The best adjustment you can do is about at your right foot level. The other important one is between your ears.Debbie C wrote:Does anyone have any info on why a few of use would be getting such a different mpg? Is some adjustment needed?
Pescakl1, I do not find that in the least helpful I'm not stupid. I drive conservatively, use cruise control whenever possible and obey speed limits. I don't do jack rabbit starts, heavy foot driving or drag racing. This car is not getting what it was purported to nor what others on this forum have posted.Pescakl1 wrote:
Change your way to drive and you will get what we get.
There is no miracle, this is just physic laws at work.
Debbie, your Rogue is still very new and not yet broken-in yet, your mileage will likely increase substantially as the engine breaks in. It's worthwhile reading the section in your owners manual on "Engine Break-in" to make sure you do everything you can to ensure a proper break in and optimize your new vehicle. Follow the break-in procedure carefully for a few months and then re-check your gas mileage, I'm sure you'll see a significant improvement. I'd also recommend reading the thread on this forum titled "Engine Break In", which you can access from the glossary/index. Also, if you live in an area with cold winter weather this will really reduce your mpg's as well.Debbie C wrote:After reading this thread, I am not sure if I want to cry or hit something. I've had a 2011 Nissan Rogue AWD for one month. I am on the third tank of gas and with each tank, the mpg has worsened. I drive approximately 70% highway and most of that is with cruise control on. MPG first tank was 22.2. Second = 21.7 Third looks like it will end up being 21.5
I called the service department and they said that was within the mpg estimate on the sticker. I replied that mpg for city was 22 and I wasn't even getting THAT for mostly highway driving. He said that below that 22, the sticker says "18 to 22" for city. What?? He said there was nothing they could do about the poor mpg. This sucks. The mpg was a selling point for me and I am disgusted. I see there are a couple of other posts with similar mpgs as mine while the majority are FAR better. As I said, disgusted.
Keep in mind we all drive very differently. I'll use myself as an example:Pescakl1 wrote:The best adjustment you can do is about at your right foot level. The other important one is between your ears.Debbie C wrote:Does anyone have any info on why a few of use would be getting such a different mpg? Is some adjustment needed?
You need to get at least + 3000 miles before the engine/transmission is fully broken in. During this period, the best thing you can do IS NOT use the cruise control. Constant speeds are about the worst for engine break in, it may also slow the self calibration process of the engine and CVT computers.kerrton wrote:Good luck and please report back to us after you've put a few thousand miles on your car!!
That is exactly what I was saying: You want better fuel economy, change your way to drive.philipa_240sx wrote:Keep in mind we all drive very differently.
I drive In the same enviroment. I have an SL with 50 k miles on it I'm getting 18 mpg at best. . I'm have to say I'm disappointed. 2002 x type jaguar got 17 mpg, 2000 BMW 328i (manual) got 21 mpg. .....average speed is 15 mph not that that tells us much other than west LA traffic sucks. If I drive the way I'd like to drive I go down below 16 mpg!DC_Rogue wrote:OK, so I am about to turn 7,000 miles on my 2010 Rogue S- I would say about 90% of those miles are all city driving.
I mean the worst of it to- rush hour, stop and go, block by block stop signs...
I am averaging about 19MPG- sometimes a bit more, but on average, 19.
I'm happy with it, my other cars that we smaller were getting about the same MPG's. I can normally go about 2 weeks before I have to fill up again (about 250-ish miles).
I'm going in for an oil change at the end of the month!
If it is stuck at 3000 rpm that would definitely account for the poor mileage. Our '10 Rogue 2WD is averaging 22 mpg with suburban driving (75% city, rest on expressways) and does ~28 if all highway. It normally revs to 2000-3000 when starting out, but quickly drops to about 1500 rpm or less once up to speed in city driving. You might try resetting the computer and let it re-learn.jrr wrote:Posted a few months ago re the bad MPG, just filled it up and got 17.5 mpg. My wife drives the car and its about 99% city. Her prior car was a 2010 Outback 2.5 with CVT and she was averaging 24mpg. Same woman, same circuits, same gas station. Her OB had 4700 when they bought it back after 12 months. She is no newbie to CVT driving. She never goes over the speed limit.
The limited time I drive it, the CVT seems to stick up at 3K+ even when feathering the gas peddle, the Subie would quickly drop down to less than 2 K in same situation. Wife's experience is the same. Car has 1500 miles on it after 4 months, understand the break in bit, but not sure how she will pick 5 mpg. Any chance there is an issue with the CVT, don't think it should be staying up in the 3K range all the time. Heck my 400 hp BMW gets 21 mpg around town, and weighs the same.
If this is the expected range, may be time to look for an alternative. Looking for guidance, again she babies the cvt like crazy, so coasting is an alternative I guess [tongue in check].
Philipa, I know it is a silly question, but I take this "break-in" period very seriously: I drove my Rogue for about 35-40kms on highway for 4-5 times. I tried to vary my speed by changing lanes (on mid lane at 100km/h for 5 minutes, on right lane -behind an old ladyphilipa_240sx wrote: You need to get at least + 3000 miles before the engine/transmission is fully broken in. During this period [...] Constant speeds are about the worst for engine break in, it may also slow the self calibration process of the engine and CVT computers.
[...]Avoid long stretches on the highway & constant speeds... keep them to a minimum.
