CHATROOM: MPG 1st & 2nd Gen
daytrippr
Car: 2008 Nissan Rogue SL AWD
We are quickly approaching 35K miles on our 08 AWD SL Rogue
We consistently get 27-28 mpg. Great car! (great new CVT!)
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
jeffmetanna wrote:Currently I have about 400 miles on the meter, and this is my 3rd fill-ups already. My in-dash monitor currently reads 16.4 MPG. I drive about 70% local & 30% highway. I've never seen it go up more than 17 MPG.
So what do you guys think?
Well when I first recieved my vehicle. I had 13-15 MPG on the onboard computer with the first couple of tanks. I reset the onboard computer for the MPG computation so I can start anew. Now I have been getting 22.8 MPG in city. My highest was 24.2 MPG but 22.8 - 23 MPG has been my norm lately. I have around 2800 miles presently on my odometer.
Please note I go by the on-board computer even though accuracy is questionable from what I read.
Modified by casperfun at 7:06 PM 11/6/2009
Elton Noway
Car: 2009 Rogue SL FWD Phantom White Black Cloth
jeffmetanna wrote:... after reading some of your postings, now I'm deeply concerned that I might have gotten a lemon.
Not to worry. Give it some time, it will get better as others have reported. I'll admit I was worried when I first got my 2009 FWD. I experienced the same disappointing results as you when it was new. After 5 fill ups my best result was only 19MPG. However I've since had my first oil change and my Rogue now has 3800 miles on it. We just returned from a highway trip (with the A/C on for about half the trip) and I calculated 25.5 MPG (the dash computer registered 27.1) This is my best MPG yet Per my gas log the MPG in my Rogue has been slowly creeping up (about two tenths of a mile per gallon) with each fill up.
NOTE: I also switched from dino oil to synthetic (Mobil 1) which has been reported to improve fuel economy due to lower friction in the engine.
rouge-rogue
Car: 09 Nissan Rogue S AWD
2009 Rogue S AWDcity 70% hwy 30%using superstore gas1st refill at ~500 km 12.8 L /100 km (AC on 100% of the time)2nd refill at ~1100 km 9.8L/100 km (AC on for 1 or 2 trip)3rd refill at ~1700 km 10.3 L / 100 km (AC on for 5 trips)4th refill at ~2100 km 10.39 L/100 km (AC off, turned on heater for 4-6 trips)5th refill at ~2800 km 10.47 L/100 km (heater on low all the time)6th refill at ~3300 km 10.6 L/100 km (heater 100% and AC for defogging)
ahhbeebee
Car: '08 Rogue SL FWD - Pearl White
I would consider that mileage a little on the low side, but others have reported those numbers too. I along with many others have found that the CVT mileage is ENTIRELY dependent on how you drive. Any weight to the accelerator and the engine rev's up relatively high and does not fall down for some time, but with an extremely light foot, the vehicle is capable of some great mileage.
ahhbeebee
Some more data from my last 6 tanks - 100% highway - Odo between 35,000km-40,000km
Mean - 26.4 MPG (9.04 L/100km)Max - 30.4 MPG (7.79 L/100km)Min - 22.9 MPG (10.34 L/100km)
All in the US, so Winter gas probably not a factor. My experience really highlights how dramatically mileage drops off when the engine is revving at >2500 RPM (23MPG) when travelling at 110km/h or faster vs. at around 2000 RPM (30 MPG) when cruising at 90-100km/h.
For those with low mileage, I find A/C, tire pressure, rate of acceleration, winter gas, can all contribute about 10% plus/minus to your mileage. So if you optimize each of these, you can potentially improve mileage by 40-50%.
Pescakl1
Car: 2008 Nissan Rogue SL FWD
Iridium Graphite
Great post Ahhbeebee, could have not explained it better .
rouge-rogue
Another factor that can affect gas mileage is if the fuel contains ethanol. I heard that ethanol makes your exhaust cleaner but it also makes your mileage suffer.also some gas stations have bad/tampered pump so it actually dispenses less fuel than what you are paying.
THawks
Car: 2010 Rogue SL FWD Premium Iridium Graphite
First fill on my 2010 SL FWD321.2 miles/14.2 gallons = 22.6 mpgTrip computer put me at 23.2 MPGMileage on the vehicle at fill up was 325, it is only about 9 days old.
THawks
Fill up number 2:2010 SL FWD332.3 miles/14.0 gallons = 23.7 mpgTrip computer put me at 24.4 MPGMileage on the vehicle at fill up was 654
rouge-rogue
2009 Rogue S AWDcity 70% hwy 30%using superstore gas1st refill at ~500 km 12.8 L /100 km (AC on 100% of the time)2nd refill at ~1100 km 9.8L/100 km (AC on for 1 or 2 trip)3rd refill at ~1700 km 10.3 L / 100 km (AC on for 5 trips)4th refill at ~2100 km 10.39 L/100 km (AC off, turned on heater for 4-6 trips)5th refill at ~2800 km 10.47 L/100 km (heater on low all the time)6th refill at ~3300 km 10.6 L/100 km (heater 100% and AC for defogging)7th refill at ~3900 km 10.9 L/100 km (heater 100% and AC for defogging)
philipa_240sx
Not bad mileage Rogue-rogue. Unfortunately it won't improve much till spring as we are now using winter gas formulations, idling more, etc. By then you will have a few more km, the engine break-in will be complete and you should easily get mid 9's or better.
ahhbeebee
philipa_240sx wrote:Unfortunately it won't improve much till spring as we are now using winter gas formulations, idling more, etc.
Yeah, nothing kills good mileage faster than -30 degrees Celcius, but at least we aren't getting the -58 (with windchill) like Edmonton.
THawks
Fill up number 3:2010 SL FWD325.3 miles/14.1 gallons = 23.1 mpgTrip computer put me at 23.9 MPGMileage on the vehicle at fill up was 979
Average temp this last tank was about 30 degrees Fahrenheit
koolyce
Car: Rogue SL AWD 2009
I'm not sure about that...
My last fill up...16.1L/100km.
I didn't use my remote starter, I didn't do some "drift" and I run the engine really smooth all the time, specially when the motor is cold.
philipa_240sx
koolyce,
Winter really effect fuel mileage. Fuels are formulated differently during winter months and it is quite common to see a drop in fuel economy even if your driving does not change.
As for my latest fuel economy test:
9.4l/100km or 25mpg - 40% city, 60% highway
This is down from my summertime mileage of 8.0 l/100km or 29.3 mpg.
Linds
Car: 2010 Rogue SL FWD, Gotham Gray
So glad I read this. I was starting to get a little upset that my averages for my first two tanks were around the 19mpg range. Between reading about the break in period and watching how I drive as the Rogue's warming up... I'm already just shy of 24 mpg on this tank
koolyce
You are all pretty lucky because I stay always aroun 14L/100km right now in the winter. Even when I drive slowly, gently, highway, my consumption is still high.
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Linds,
That's great news, I'm always glad to hear that our forum was able to help somebody out, and maybe the environment and air quality benefited a little bit too because you're now driving more efficiently.
Koolyce, like Philip said, you'll get much better mileage once spring arrives, my mileage plumments in the cold Alberta winter too, and I really dislike how the Rogue sounds and drives when it's really cold so I have a tendancy to warm it up more than I've done with any other vehicle. Also, the Rogue seems very slow to warm up when driving so if I don't pre-warm it I end up driving almost the entire way to work with the engine rattling and the CVT geared too low so I avoid this by warming it up a few extra minutes before leaving. Not the best advice, I know, but it's what I do and my point being I don't get very good mileage in winter either!
koolyce
I'm still getting 14-16L/100km. I don't use remote starter and I didn't let the car running on standby more than 30 sec...
I hope it will change next summer... my consumption is like a V6.
rouge-rogue
2009 Rogue S AWDcity 70% hwy 30%using superstore gas1st refill at ~500 km 12.8 L /100 km (AC on 100% of the time)2nd refill at ~1100 km 9.8L/100 km (AC on for 1 or 2 trip)3rd refill at ~1700 km 10.3 L / 100 km (AC on for 5 trips)4th refill at ~2100 km 10.39 L/100 km (AC off, turned on heater for 4-6 trips)5th refill at ~2800 km 10.47 L/100 km (heater on low all the time)6th refill at ~3300 km 10.6 L/100 km (heater 100% and AC for defogging)7th refill at ~3900 km 10.9 L/100 km (heater 100% and AC for defogging)8th refill at ~4400 km 10.8 L/100 km (heater 100% and AC for defogging)9th refill at ~4900 km 10.6 L/100 km (heater 100% and AC for defogging)
xmiranda
I think the digital mpg is set on the conservative side. Most of my mileage is highway and, after about 38,000 miles, I have calculated 27.4 mpg while my digital readout says 26.2 mpg. (FWD SL)
rolade01
Car: 2010 Nissan Rogue SL AWD Carbon Silver Black/Blue Cloth
I'm more than a bit disappointed so far. I picked up my Rogue just after New Year and am getting the fuel efficiency of my former 2002 Chevy Malibu 6 cyl. I have been refilling shortly after the low fuel light comes on. I don't know if we in Vancouver use winter grade gasoline, but so far I am unimpressed.
2010 SL AWD Using Esso 87 Octane90% city/10% hwy1st refill of 55 L, tripodometer reading 390 km 14.1/100km 2nd refill of 54 L, tripodometer reading 379 km 14.2/100km
Modified by rolade01 at 7:06 PM 2/3/2010
rouge-rogue
rolade01: I also live in Vancouver, I find that some station cheats you by having pumps that give out less fuel than what you paid for. from experimenting I find that pump # 6 (marked as for suv and trucks) at my local superstore gas bar gives the most accurate gas dispensing so I always get my gas at the same pump every time.
2009 Rogue S AWDcity 70% hwy 30%using superstore gas1st refill at ~500 km 12.8 L /100 km (AC on 100% of the time)2nd refill at ~1100 km 9.8L/100 km (AC on for 1 or 2 trip)3rd refill at ~1700 km 10.3 L / 100 km (AC on for 5 trips)4th refill at ~2100 km 10.39 L/100 km (AC off, turned on heater for 4-6 trips)5th refill at ~2800 km 10.47 L/100 km (heater on low all the time)6th refill at ~3300 km 10.6 L/100 km (heater 100% and AC for defogging)7th refill at ~3900 km 10.9 L/100 km (heater 100% and AC for defogging)8th refill at ~4400 km 10.8 L/100 km (heater 100% and AC for defogging)9th refill at ~4900 km 10.6 L/100 km (heater 100% and AC for defogging)10th refill at ~5300 km 10.9 L/100 km (heater 70% and AC for defogging)
rolade01
Hey Rogue-rogue - which Superstore Gas Bar do you use? I live near UBC so the closest one to me is the one on Marine Drive. I sometimes shop there or at the one in Richmond. I've been watching your posts and it was making me think there must be something wrong with my Rogue. I want to experiment before I take any action with my dealer. Thanks in advance.
rolade01
Well I wonder how many people are havig the less than stellar fuel efficiency that I am. I will be taking this up with my local service department to find out what it could be.
Here's a useful link to calculate your fuel consumption: http://calculator-converter.co...r.php
2010 SL AWD Using Esso 87 Octane (switched to Shell 87 Octane for my 3rd tank)90% city/10% hwy1st refill of 55 L, tripodometer reading 390 km 14.1/100km 2nd refill of 54 L, tripodometer reading 379 km 14.2/100km 3rd refill of 59 L, tripodometer reading 375 km 15.7 L/100km - absolutely horrible mileage!
Modified by rolade01 at 7:29 PM 2/15/2010
tensman
2WL, SL, 2009 with 8000 miles, last 500 mile trip of combined city hiway (mostly hiway) yielded 28.2 mpg. Very happy with this vehicle! Love that CVT!TLenoir City, TN
philipa_240sx
rolade01 wrote:Well I wonder how many people are havig the less than stellar fuel efficiency that I am. I will be taking this up with my local service department to find out what it could be.
Are you saying you have only put 3 tanks of fuel in your Rogue so far? There have been reports (myself included) that it can take at least 5000km or more before the fuel economy will settle down. There are several reasons for this:
1) Engine break-in: A new engine has fairly high friction and it can take +5000km for break-in to complete.2) ECU self learning: The engine can take several thousand km to fine tune the air/fuel ratio.3) Winter fuel: Typically I see a 1-2 l/100km decrease in fuel economy during winter. This is partly due to the effects of cold weather (long periods of idling, longer warm-up times), and additives in the fuel to promote cold weather starting.
By all means, take it into the dealer and have them look at it.
Finally, what type of driving do you do? Is it mostly short trips less than 15 min? Lots of stop and go traffic? Both of these will severely impact fuel economy.
koolyce
I have actually the same kind of mileage as you. Even if I drive slowly, carefuly, etc...I can't go under 12L/100km.
I will wait for summer and see if I get better milage. I hope so.
rolade01
philipa_240sx wrote:Finally, what type of driving do you do? Is it mostly short trips less than 15 min? Lots of stop and go traffic? Both of these will severely impact fuel economy.
I usually do short trips between 5 to 20 kms. 90% of my driving is in the city - stop and go if you will. Surprisingly traffic in Vancouver now is not really bad even with the Olympics in my area, but of course traffic lights are abundant. I do run out to the suburbs every weekend and get some good highway time though.
I'll follow up this post after talking to my service department rep.
Return to “Rogue Forum”
