Ah, now I see what you did. Your calculation is correct then.RO-G wrote:But in my case, instead of using liter/km, I used 11.5 km/liter.
In my opinion, if the American posting for mileage in this forum is MPG (miles per gallon), the Canadian mileage should be posted as KPL (kilometers per liter) which was what I did. Now, if the American mileage is posted on this forum as Gallon/100Miles, then it is right to post L/100Km for the Canadian mileage.philipa_240sx wrote:
In the future however, please post your mileage as either l/100km or US mpg. This way we can avoid any confusion.
Yes, that would make 'logical sense', but no-one else uses km/l. The metric standard is l/100km. This is what the mfg's, government, car magazines, etc throughout the world use.RO-G wrote:In my opinion, if the American posting for mileage in this forum is MPG (miles per gallon), the Canadian mileage should be posted as KPL (kilometers per liter) which was what I did.
Dealing with mpg and l/100km conversions are confusing enough... we don't need to add a 3rd measurement.
Just a suggestion ... I think it would be better if forum members also post the total mileage reading of their Rogue at the time the fuel mileage is taken.ahhbeebee wrote:Latest tank: 7.96L/100km - 29.75MPG
A combination of summer gas, and a recent speeding ticket has me getting great mileage again after somewhat mixed results in the winter.
FYI: I still keep track of km/L (just don't post them)
No wonder you're getting good mileage out of your Rogue.ahhbeebee wrote:All within the City, but roughly 70% Highway:30% City (cruising at 85 km/h - 1600RPM - cruise control)
OK, done!Pescakl1 wrote:I already fill my tank with a little bit more than 68 liters (about 17.9 gallons), but I usually try to fill it until I see the fuel (not wise I know).
So you can say that the tank is at least 17 gallons.
With the squares, when you only have two left (the tank light should just have been on at that time), you have about two gallons left in the tank, about 100kms (60 miles).When the last square disappears, you are on fumes (less than 10 miles to go).
I don't know the computer as I don't have it on my car, but this kind of thing are known as quite inaccurate. You should base your estimate on your mileage, that is the most precise way to know, with a look on the gauge and your computer.
Even the scangauge I got could give me false confidence and I should take its figures with caution.
Right now, I am aiming to get 900kms on the current tank, I will tell you if I succeed at the end of next week.
Sorry if I sound like one of your old driving school teacher, professional deviance I believe or remanescence of my french arrogance .lou from ny wrote:sounds like the guy in driving school all over again...lol
Like Philip said, give the car a chance to prove you what it can do with more mileage on the car and more time driving when warmed up.lou from ny wrote:i'm not trying to set efficiency records, just see if anything is wrong or if the stated claims are false, but thanks for the tips anyway lou
The 1200mi. (2000km) is just the break-in schedule. Afterwards you are permitted to drive normally. However, the overall engine/transmission break-in period can take 5000mi or more.RO-G wrote:I thought the break in period was 2,000km only as per Owner's manual.
The last 3 tanks I've gotten between 26 and 27.5 mpg with the ac sporadically. However this tank, since last Wednesday, I have run the ac probably 97% of the time. So far the computer shows 24.2, when it would usually show 26+ at this stage of amount of fuel used. I'm just under halfway thru the tank but I will post my final numbers.ahhbeebee wrote:Since we are now officially warm and summer (and some of you to the South have had warm weather for some time) - I'm curious.
For those using A/C almost 100% of the time, what is the difference you see in your mileage with and without A/C? I use it too sporadically to get any reliable numbers to compare.
