larry80 wrote: ↑Fri Jul 21, 2017 2:25 pm
Having searched the forum and not finding an answer, can anyone tell me what the number indicates after the words "Fuel Economy" on the dash?
When we first bought the Rogue it said, "Fuel Economy 1". Now it says "Fuel Economy 2". Would this be in reference to trip settings?
On the 2017, the "1" is a long lasting number. It resets on it's own at some point, after the millage rolls over some number, not sure exactly what, or you can reset it manually. The "2" is the current trip since you started the car. Use the up/down instead of left/right to switch between 1 and 2 for the average MPH, time/distance, and MPG screens.
So, if you reset them all, then drive they'll be the same. Stop and drive some more, now the 2 is only the second drive and the 1 is the total of both. On a long trip with stops, if you reset at the start, 1 would be overall and 2 the current leg.
I think of it as 1 is the ongoing average since the last roll over and I never reset it. While 2 is the current trip, usually checking while I'm commuting to work. It's not perfect, but close enough for me to know if I'm trending up or down.
