Rogue Jarhead wrote:The mileage will get better as the engine gets broken in. Try pen and paper calculation, those computer calculators are rarely accurate. I have two vehicles with them a Rogue and a Caravan both are typically off 10% or more.
How many miles before it gets better? My MPG readings are paper calculations. We keep track of every mile in a gas/fuel book. Our average has been going down since we bought it, but had a slight uptick once we turned off auto-climate control. Still, we are averaging around 24'ish and we are trying really hard to be easy on the throttle, keeping the usage in the 'green' zone on that fuel dashboard screen. Our Rogue's computer shows as 0.8mpg higher than actual.
Frzninvt wrote:Could be your driving style. I have a 2016 SL and I am averaging 28.7 MPG and I track it via Fuelly. I had been getting 30 mpg but with the temperature dropping in my neck of the woods so has my mpg. I was running mine in Eco mode as well for awhile, we went on a 250 mile trip with A/C and 75mph speeds and I still managed to get 29.9 mpg. You can check Fuelly.com to get an idea on what others are getting. I did replace my stock air filter with a K&N but other than that it's stock.
I honestly don't know how we could use less throttle in our Rogue. In some cases we are so light on the throttle (keeping in the green zone) that we cannot even reach a full 60mph/freeway speed (wind resistance I guess, is more powerful than the light throttle usage trying to keep it in the green).
Reading through this thread, I'm really starting to think something is wrong with ours. Although fuelly.com shows 25'ish average for the 2016....which also seems really low since it's suppose to be 26/33. We keep a record book of every single gas fill up and mileage has been decreasing. We actually hit about 32mpg on the drive home from the dealership when we bought it, we've only seen 30+ once or twice since then on trip, but our tank average has been 23/24'ish.
