S13FX »
https://forums.nicoclub.com/s13fx-u28329.html
Fri May 04, 2007 7:53 am
You know what else I was thinking about the whole idea of hanging your turbo on hangers.
It will also kind of work like a flex pipe giving a turbo the mobility when under TQ, there for less broken parts. I'm sure there is some downsides to this, but with the setup being so much cheaper.
Now I was thinking of testing my oil lines, the same concept as you would with a normal setup. I'm guessing with the width and length of oil lines, I will probably need to add about an extra Quart in to the engine.
Now, how do you plan on running your oil pump? Cause I was thinking about doing it as soon as I turn the key over it goes on, but then I would realistically have to turn the engine on right away too.
Unless the pump has enough power to be able to pull oil through the feed line and recirculated it right back into the engine while the engine is off, in which case I wonder what the negative outcomes are of that are.
Now putting it on a manual switch has crossed my mind too, but there will be that one day that I will forget to flip that thing and realize it when i hear BOOM.
All Ideas are welcome.
Thanks,Mike
