maxnix wrote:1.) Wrong again. At least you are consitent!
2.) Since you have never removed your plenum, you obviously don't know about the EGR tube inside the plenum.
Every village has its mentally challenged person and this board has you.
You know, I'm really trying to help people here, why don't you participate?
1.Yes, a $6000 machine will catch the misfire, just as Tech said, how many people have one? Not many, and certainly nobody on this board and nobody that is trying to solve this problem. Will a hand-held OBD-II scanner find a misfire that HAS NOT triggered a Check Engine Light? No.
2. Cleaning the intake/plenum is not cleaning the EGR system. Regardless of how they are connected.
And even though I haven't pulled my plenum off, I did know that the EGR system is attached to the intake. How?
Announcement for everyone reading this thread!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Maxnix solved his misfire by replacing a bad coil, not sure which one, or how he discovered which coil was bad-he won't say. It would be very helpful if he would.
He did not solve it by removing his plenum, cleaning his plenum, cleaning his EGR, or by cleaning his ears.
