dodiho wrote:hey Guys...I FINALLY fixed my herky/jerky misfire problem...after cleaning TB and MAF...remember I was the one that met a senior Infiniti mech in line at a BBQ place and bought his meal if he'd tell me a few things...his best technique was to tap on the side of the MAF plug and cover with his pocket knife with the motor idling-IF tapping caused it to rev up,stumble or die-the culprit was the sensor board INSIDE the MAF body...he said road vibrations over time sepaerate the solder joints.....I put a rebiult one from Cardone in it last Saturday morning in about 15 minutes..went on a 300 mile trip that afternoon...not one misfire or glitch.....I did do all the suggested maintenance too: changed trans fluid,changed oil/filter, air filter, injector rails cleaned out,etc....but this was before I changed the new MAF....hope this helps.....I saved tons of money by doing it myself and have sent the old one back to recover my core charge.....dodiho in central Texas
G50 owners have taken their MAFs apart and also found these same breaks in the circuit board. It could very well be the gremlin Y33 owners are being plagued by.Qproject wrote:when you replaced your MAF, did u have to remove all the sensors and re-install them ?
it could have been just dirty connectors no ? just a thought.
Have you replaced the ABS relay yet?dodiho wrote:I had already cleaned all the sensors involved in fuel/air flow loop....nothing helped...it got so bad that it would idle and die when I turned ac on...I didn't really want to spend the $ on a new MAF..but glad I did now..it runs like it was meant to ... I think the culprit with most of our "stutter" problems IS the connector/circuit board under the raised square part of the MAF....I have more trouble with the ABS SLIP lights staying on ...for no reason...
It's not as you will see if you read the previous thread on this subject. Well discussed in that thread also, even by people looking for a magic bullet, which dosen't exist.beancan wrote:Seeing this as an unsolvable problem..
Any thoughts are appreciated - its just a discussion
-Bean
Q_SHIP wrote:My god guys!! ks and harness. Just bite the bullet and do it.
