OK. Why is that? The failure rate of the newer cars? My recent purchase of a 2000 had the coils changed at 77,894, currently 93000, by the dealer under warranty. All of them. In Miami. AT $ 99.00 "gulp" shop rate "gulp". 2006. South Motors Infinity. On Dixie Highway, Miami. . Talk about whistling Dixie ? ? ?Q45tech wrote:90-95 coils are very different from 97-01. The odds on a coil failure in 90-95 are like 100,000 to 1..............we]ve never seen one in thousands of repairs.Now bad seals in valve covers allowing oil into plug well and on coil extension are common but you spray clean the extension, dry, and reinstall along with new plugs every 60k and things are golden.
google searchAnswer: This problem is difficult because the computer can't detect a problem, your car thinks everything is ok. In reality what is happening is the electrical component inside the MAF sensor becomes contaminated by impurities in the air (heavies) These containments imbed themselves to electrical component that senses the air flow causing the sensor to be slightly off, but not enough to trigger the MIL (malfunction indicator lamp). Replace the MAF sensor with a new sensor and you're problem will go away, plus your car get better mileage and performance. (Mass Air Flow MAF sensor or Air Intake Sensor AIS, depending on manufacture. It does the same thing with different names).tt300z wrote:OK LETS MAKE THIS CLEAR....missfire at idle is IGNITION COILS period!!!!!
now if you have no power or stumbling at around 2k to 3k and no check engine and no codes IT IS YOUR MASS AIR FLOW when it goes out totally you will get TCS OFF.....SLIP.....AND SEVICE ENGINE SOON LIGHT...ALL AT ONCE.....the car will run like **** ..... NOW THE MISSFIRE THAT IS DRIVNG EVERYONE NUTS AROUND HERE IS IGNITION COILS "for sure"
hope this helps
On OBD2, if you are having ANY cylinder misfiring....the check engine light should be illuminated unless the bulb is burnt outmiata007 wrote:Is it possible to use OBD II top scan which cylinder mis-fire without engine check warning on?
007
How much were all 8 coils? I'm had that I don't have this issue yet.bullittandy wrote:I solved the idle stumble on my 99 by replacing all 8 coils. The problem was intermittent and I waited for a code/CEL but never got one. Let me repeat, the engine would stumble noticably at idle and sometimes would not and there was no CEL/MIL/codes as read by two different OBD-II scanners.
I got tired of the stumble, bought 8 new coils and THEN (damn car!) the MIL/CEL illuminated but at that point it didn't matter since I had 8 new coils to install. I replaced all the coils and the car runs as new and has for several thousand miles now.
It's a good thing, as is updating your profile with the year/model/etc. of your car. I assume you have a '97-'01? The only reason I ask is that the 90-96 rarely have coil pack failures due to a different design. The newer ones haven't shown many failures yet either - we're not sure if that's a function of a better design, or just that they're newer and haven't started failing yet.mc_rhett_meister wrote: p.s.- sorry to bump such an old thread, but I assume its good to keep this one up.
Heath, Sorry about that, done and done! Well I went through it all, found that my driverside VC gasket was bad(leaking ontop of plug/coil 1 and 2 Replaced that and every coilpack and plug with new from IOS. Helped a lot with the really low end idle chugging, but still missing throughout the powerband. Im going to check out the EGR tomorrow and if that checks out, my friend is going to cut out my cats and weld in test pipes! Question, I look underneath the car and coming directly off the manifolds are the cats, only flanged at the manifolds, but welded to the midpipes. What is downstream appears to be 2 more cats and then resonators, is this correct, 4 cats total?! TIA RhettQ451990 wrote:
Heath
http://www.nicoclub.com/FSM/ Look at the FSM for all questions about cat. You will learn a lot which is better than someone spoon feeding you the answers. I had to do the same thing and now I'm very familiar with the fsm. Also my left cat is leaking and I was thinking about cutting both off but I was afraid of how it would sound afterwards. Let me know the outcome!mc_rhett_meister wrote:So Heath, Sorry about that, done and done! Well I went through it all, found that my driverside VC gasket was bad(leaking ontop of plug/coil 1 and 2 Replaced that and every coilpack and plug with new from IOS. Helped a lot with the really low end idle chugging, but still missing throughout the powerband. Im going to check out the EGR tomorrow and if that checks out, my friend is going to cut out my cats and weld in test pipes! Question, I look underneath the car and coming directly off the manifolds are the cats, only flanged at the manifolds, but welded to the midpipes. What is downstream appears to be 2 more cats and then resonators, is this correct, 4 cats total?! TIA Rhett
cariduro24 wrote:Have anyone find it a solution for this issue?
good call. stopped by autozone and they are the same for maf's and coils.Q451990 wrote:I would think they're compatible... you might want to check on some of the aftermarket parts web sites like Advance Auto or Autozone to see if they sell the same part number for both cars.
Heath
