Heheh, Andy ... with all due respect, you're merely dismissing the advice.
Let me say for the experts - "The Solution is Unclear".
I did some thinking about this on a long drive yesterday. Let's start calling it a "syndrome". It's becoming obvious that there isn't ONE cause for these misfires. If anything, I would say it's the fault of the Y33's ECU programming. For one reason or another, the VH41 will misfire. Sometimes, it's at idle, sometimes it's on a long highway upgrade in 4th gear. Sometimes it's accelerating mildly in city traffic.
I haven't seen any evidence that it's fuel-delivery related, so we look at electronics - sensors, connectors, etc. We look at the air-delivery path. Reread what Q45tech said:
q45tech wrote:We diagnose systems record reams of data and meditate on the dozens of voltages >... < when the stumble occurs you push the bottom and you have the voltages associated with the event.........nothing out of the ordinary you monitor 12 different ones eventually if you understand the ecu workings totally in your head you'll find the culprit > ... <we swap and eventually zero in on the things that don't throw codes. [coils, ecu, maf, etc etc.]
Isolating ONE component requires bringing each one up to spec, either by swapping or cleaning, etc. Unfortunately, if MORE than one is suspect, they ALL have to be right to solve the problem - kind of like how replacing your struts won't fix everything wrong with the suspension.
I have another suggestion: Texasoil swears by a dielectric connector treatment called Stabilant-22:
Stabilant-22 ... Miracle cure!!
Someone (or everyone) should clean their MAF and treat the connector and all other connectors they can get at with Stabilant-22. If there's any improvement, that will be significant. It's cheap.
Someone should get a BG intake cleaning - same idea - improvement says that intake condition is a factor. It's not expensive.
Etc.
Here's an interesting thread that I found by taking Brian's advice and searching old threads (hint, hint):
maxnix wrote:Wife got tired of stumble, so off came intake for a kerosene cleaning, and same for EGR and IAC valve. Used only carb cleaner on lower runners. Seems to have cured the stumble. Will let you know later. Dremel helps a lot, but inside of penum is really rough cast with lots of nodules on the surface. Cleaned as best I could.
'97 Q45, stumbling idle
