Bumnah »
https://forums.nicoclub.com/bumnah-u39849.html
Tue Mar 03, 2009 6:36 pm
Had some free time so I took care of a few things.
Ran most of the vacuum hoses.Recirculated the BOVCut some tubing as trimming for some edges.Small stuff, but stuff that needed to be done.
Pix:
Ran the piping for the Oil catch can.
Used a radiator hose to recirculate the BOV. There is a slight kink, but it'll have to do. It should be fine as is, we'll find out.
Another shot of the recirculated BOV. I'm so glad it's finally recirculated!
I also ran all the vacuum lines for everything except for the wastegate. I'm just waiting on the boost controller to arrive. I already know how I'll mount it, and where I'll mount it.
I tried to finish up all the small thing and tidy up the bay a bit. There are hoses running every which way. Real men don't tuck wires.
I cut up some old vacuum hose to run along the edge of the hotpipe hole.
I did the same for ghetto oil cooler mount. It had some jagged edges, last thing I needed was for one of the oil lines to get punctured by 'em. I also ran a cut up hose along the edge of the radiator where the lines may rub against as well. I even cut up some rubber tubing and covered some exposed bolts.
After the lines were run, I went to Lowe's and bought some pieces to make a battery tie down. I'm using a 6" long threaded rod. I will use nuts and lock washers to screw it to bottom of the battery tray/frame. Then bend a piece of aluminum plate to hold down the battery. Total cost $3. Eventually I'd like to do a relocation for the battery behind the passenger seat.
Enjoy.
Modified by Bumnah at 11:51 PM 3/3/2009
