Bumnah »
https://forums.nicoclub.com/bumnah-u39849.html
Mon Feb 02, 2009 9:41 pm
Update!
So. I did a bunch of stuff. It's been slow going because I'm fixing a bunch of small things that need to get done. Plus I've been hitting over 55+ hours a week at work.
Anyways less talkie talkie, more pictures.
New Oil catch can. Yes it's baffled
How it'll mount up:
Mounted my Setrab oil cooler. I'm making a bracket for the top as well. It's not pretty but my tool collection in fabrication is equivalent to a rock and my teeth.
Mounted the S14 throttle body pulley to my S13 throttle body. I also cleaned the inside of it.
Mounted up my oil pressure sensors on the oil block. The adapter is a Defi NPT to PT adapter. I couldn't use it on the side, it pushed the sensor too far out, and it hit the starter. I used some high temp thread sealant. Hopefully it holds.
Modified the fuel rail for the GReddy manifold. Had to trim one of the tabs, removed one of the tabs.
Had to modify the FPR too. Not my best work, it should work, if not I gotta redo this too.
Had the front S14 LCA's fitted. New Super Pro poly bushings, with new outer sleeve. MOOG S13 ball joints. Had them boxed in as well, sand blasted and painted. All work done by MA-Motorsports.
Boxed in:
Modified the hot pipe to have a vacuum fitting added. This will be used to feed the waste gate and the manual boost controller. Again MA-Motorsports...
Pic 02:
Cheap ebay intake tube, modified to have recirculation fitting. NO MORE FIRE OUT OF THE EXHAUST! Again MA-Motorsports...
Now the piece de résistance. I was going to paint my intercooler black. Then I decided I didn't want to. The end tanks are already black. The intercooler needed something. It needed a logo. GReddy intercooler so GReddy logo? Nahhhhh. It needed this:"Bumnah" in "GReddy" font.
I'll be honest, I love it. It's 22" wide, and 4.5" tall.
Most updates this week. I'm hoping to wrap up the intake manifold and oil cooler install. Then it's on to the intercooler, which is easy. Cut hole in the battery tray area. Modify reinforcement bar. Cut bumper to clear intercooler. Oh. and put my logo on the intercooler.
Hope you enjoyed it.
More pix here.
