Bumnah »
https://forums.nicoclub.com/bumnah-u39849.html
Tue Dec 02, 2008 6:46 pm
Another couple pieces of the puzzle.
I've decided to tone back the suspension build. I'm cutting out the powder coating, I'm cutting out the aftermarket front control arms. I'm also cutting out some of the spherical bushings that are suppose to go in the uprights.
I was debating on doing an oil pump and timing belt change. That's another $400 to the build price. I was also debating on sending my injectors off to RC to have cleaned and spray pattern analyzed. I may still do the RC injector cleaning, but I may delay the timing chain and oil pump replacement.
Throttle body over boring and port matching of the intake manifold are both being delayed or canceled.
Too much $ and with this economy I can't justify the purchases. I'll have the suspension 85% they way I want it after this build.
New goodies:
GReddy gauges SMI with the control module. These things are being discontinued, so I grabbed the ones I wanted and got it over with. It took close to 3 weeks for the them to come in. I ordered the EGT gauge from FRsport and according to them I got the last one GReddy had at their NJ plant.
The control module has the peak hold function as well as 40 seconds of playback options. I primarily wanted the peak hold feature particularly for the EGT gauge. I also wanted to stick with GReddy since I already have my turbo manifold tapped for their temperature probe.
SMI control module
Oil Pressure gauge:
Oil Temp gauge:
EGT gauge I already have a 52 mm GReddy EGT gauge, but I'm replacing it with this guy:
Lastly, a new knock sensor. I got a fair price on it, and it's new, figured a decade old motor swap could use new sensors.
I'm going to hopefully get the car up on jack stands this weekend and start taking it apart. I've been waiting for the gauges to arrive so I can get started.
Next up will be the rest of the rear suspension.
Thanks for looking.More pix here.
Modified by Bumnah at 10:23 PM 12/29/2008
