I just want no hassles... dont want to make multiple trips to the dealership like FBI.... i wonder how this telephone works....?ricebike wrote:this warranty info is confirmed... i looked into it waay back in the late 90's when this was only amarok.org, a nissan 240sx only messageboard/email system...
if blksrjdm works at a local dealer, he can confirm this easily as well...
ps to lumberjack, that recall was about the plastic red button; apparently this was a defective part to other imports as well ie suzuki
Yep, the plastic breaks off, falls into the buckle itself, and keeps the mechanism from latching. I actually had it happen on my S13, I just took the whole buckle off and shook it upside down until the piece fell out. They are replacing it anyway.ricebike wrote:ps to lumberjack, that recall was about the plastic red button; apparently this was a defective part to other imports as well ie suzuki
could you possibly modify a oem seat belt? to what mod?iitywygms wrote: Just know that they will not do it for free if you modified them in any way.
i disconnected my relay so it would stay in the upright position, that may be considered a mod. also, the car was purchased with out th e factory lap belt... but they are 2 seperate pieces.... i guess ill have to take it to nissan soon to get the answer.playero_loko wrote:
If you need specifics, I switched to gtr seats, then switched out the buckle because the stock s13 buckle stuck out like a foot. Hence, modified.playero_loko wrote:
the modifiction of something is to completely change it out from its orignal form to a new one. just b/c it wasnt properly working and you did what you had to so it'd work its not a modification. ok so you modify it so it back to sotck?! great mod big buy!iitywygms wrote:
complete bs, they lied to yousmh240sx wrote:they only have to cover them if you are the original owner thats what they told me about it so i unplugged mine as well
sounds good, if they give you a service receipt can you post the part numbers please?FlatBlackIan wrote:I spoke with Nissan yesterday afternoon. 3 of my 5 parts had arrived, and the other 2 are due to arrive tomorrow.
I made an appointment to drop the car off Tuesday morning.
I had planned on it.S133P3R wrote:sounds good, if they give you a service receipt can you post the part numbers please?
No kidding, they really turned their service around. They will get an excellent customer survey when this is all through.S133P3R wrote:courtesy vehicle on a 20yr old warranty repair? sounds good
No Jacki is correct the buckle is under recall. Everything else is part of the warranty.S133P3R wrote:not a recall, just covered under warranty "under normal use for the useful life of the vehicle."i need an OEM lap belt and i should be able to get both replaced... hmmm, junkyard time.
