Jacko3 wrote:The term "fall" used in physics is not an actual fall. It is conceptual. I know this sounds strange. When a physicist tells you an object is falling, you will rarely see any physical object falling. Both horizantal and vertically placed objects experience fall due to gravity. You need not see movement to experience fall. I can't explain this concept any further. By the way, fall due to gravity is not basic physics. There is a lot more to it than we are discussing.
So you are saying my can of soda, sitting on my table is falling? It is not. Perhaps you are misusing terms here, but it is remaining motionless on my desk. The force of gravity is acting on it. But it remains motionless, because there is an equal but opposite force acting on it. That is, the normal force from the table.
Jacko3 wrote:You said, "A moving body does not negate the effects of gravity: I guess I wasn't clear when I said, "And yes, a moving body will have enough force to eliminate the impact of acceleration due to gravity. Thus, making the effects of gravity, negligible." Well, the fact is that gravity is a weak force. it is weak enough so that humans can produce enough force to overcome its ability to pin us to one spot. So, movement in a horizontal way is actually a counter effect to the horizontal effects of gravity. And. if you can move fast enough horizontally, the effects of gravity declines considerably and not totally. This is partly the reason why light is not subject to the effects of gravity, and thus has a constant speed in a vacuum.
Are you serious? Think vectors here. If you have a force pushing on an object horzontally within the field of a vertical gravitational force, then guess what, both forces will act on the object. Gravity does not decline unless the gravitational field itself becomes weaker. This can occur in areas where the mass/density is lower. It also gets weaker as you move away from the source. Otherwise, it is a constant force.
Umm? Albert Einstein proved light is affected by gravity. Black Holes are simply small dense stars that have a gravitational force so strong that even light can not escape.
http://imagine.gsfc.nasa.gov/d....html
Jacko3 wrote:Terminal velocity does not necessarily have anything to do with wind resistance. Any moving object will experience terminal velocity. lets not mix terminal velocity with maximum velocity--these are two entirely diffferent but similar concepts. When Physicists calculate velocity, they tend to calculate the minimum velocity, the terminal velocity, and the maximaum velocity. Each is used in different ways. Sometimes the maximum velocity and terminal velocity can be the same. But this is not always the case.
Terminal velocity is absolutely related to wind resistance. Drop a feather and a ball off a building. The ball will fall quickly while the feather will fall slowly. Now if, you remove all the air from the atmosphere, and do the same, both will fall at the exact same rate. This is beacause the feather has much more surface area for it's given mass, which increases the effects of wind resistance on it.
Another example is to jump off a plane. Open your arms and legs so that your body is open to the air you are rushing through. You'll stop accelerating towards the ground until you reach your terminal velocity/ Then close your arm and legs and either aim your feet or head straight towards the ground. You'll actually accelerate some more falling at a faster velocity until you hit the terminal velocity. By doing this, you change the amount of surface area being subjected to the air rushing by. This changes your terminal velocity.
Jacko3 wrote:Speed is distance travelled in a unit time, while velocity is the displacement in a unit time. Both have the same units of measurement---meters/second. Displacement is the difference between two points, which is totally and completely independent of whether the object is moving vertically or horizontally. Again, don't confuse speed with velocity. The time is takes a shaft to spin 360 degres or gears to complete one revolution covers the displacement needed to calculate either terminal velocity or maximum velcocity.
Absolutely. Speed is a scalar and velocity is a vector. Now that were past the technicalities of it, how does this even relate?
Jacko3 wrote:Again, you use the term liquid and water in cavitation. Well cavitation is a function of fluids and not just liquids. Fluids are substances that can exert pressure on a wall of a container and has some flow characteristics--meaning you calculate their flow charateristics using Reynolds number, Prandtl number, etc. Some fluids are compressible and some are incompressible. Thus, all impellers that move fluids through closed channels, will potentially experience cavitation under the right set of circumstance.
Cavitation occurs when the molecules of the liquid vaporize. This occurs as the density of the liquid drops in the low pressure areas that occur when the velocity of the liquid moves past an object. When the density drops to a point below the vapor pressure of the liquid, it turns into a gas until it slows down and the density goes back above the vapor pressure. Then the gas turns back into a liquid. Gas can not experience a physical change like the liquid does in this instance. Therefore cavitation cannot occur.
Jacko3 wrote:A dirty air filter is not just a restriction if the air has to be moved with great velocity through a channel by an impeller. The volume of air in that channel that passes over the impeller that moves it will determine whether cavitation occurs or not. For non impeller based air movement, yes, a dirty air filter is a restriction. Restriction is more a function of free flowing fluids whose movements are impeded.
An air filter, dirty or clean, is a restriction. A turbo that sucks more air through a filter simply creastes a lower pressure area behind the filter. As the pressure differential is higher, the flow will be greater.
I already explained cavitation so I won't go into more detail in the paragraph.
A turbo motor with a more restrictive or dirty filter will become a greter restriction (read: it would require more energy to reach the same intake manifold pressure).
