There seems to be some different opinions concerning spacers, offsets, and suspension component loads and wear.
IMO, it is the final offset that determines the suspension load. Not the method used to achieve the final offset.
Amusing that all things are equal except the rim offset.
Using my crude drawing. The picture on the left is using a zero offset rim with a one inch spacer.
Lets say this puts the centerline of the wheel 9 inches from the wheel bearing.
The picture on the right is not using a wheel spacer. It is using a rim that is one inch offset.
This also puts the centerline of the wheel 9 inches from the wheel bearing.
Now, using simple math. The moment equals the Distance times the Force.
On both setups. The distance and force are equal. Therefore, the moment is the exact same on the wheel bearing. There is absolutely no difference in the stress applied to the suspension components or wheel bearings.
Am I wrong?
