numbnuts240 wrote:by no means was it an accurate count. basically a summarized version. i was kind of hoping for a civilized, mature, factual, and interesting debate. but it turned out to be more bickering and mud slinging than anything else. i through you in there because in the midst of all my face palming, you provided me with a chuckle here and there. with that being said, scotty's right, you're all wrong.
Ender_Zero wrote:Also I think you are confused, the spacer is not to make it fit like a wider wheel.
For the sake of argument is not a good phrase here. Why is this still an argument? plz keep readingEnder_Zero wrote:The wheel width and tire stay the same for the sake of argument. the only change we are looking at is offset.
I admit wholeheartedly that I've not put anything into an easy to understand 'for the kiddies sake' style of writing. For those of you who found this thread while looking for info on spacers, I apologize for my part in the confusion. All of that doesn't mean that we should just drop the discussion while misinformation is out there as the last word.nissan_star wrote:Ender_Zero wrote:Also I think you are confused, the spacer is not to make it fit like a wider wheel.
spacers can definitely be used to try and make wheels 'look' wider. I understand people buy the wrong offset and use a spacer to fix it, not a big deal for the bearing when comparing to the wheel they were looking for but couldn't find. but lots of the people try to fit 8" wheels to their rolled fenders and push the contact point far away, and this is where problems occur.
IT DOESN'T MATTER THE OFFSET OR OTHER CRAPOLA, IT ONLY MATTERS HOW FAR AWAY YOUR POINT OF CONTACT ENDS UP COMPARED TO THE POINT OF INTEREST ON THE BEARING.
People shouldn't read this and think all spacers are fine, some kid will run a 7" wheel with a 2" spacer to be flush and his contact point will be hella far away from the bearing interest point. If you have a skinny wheel and are running a big spacer to get fitment, you should think about a different wheel setup if worried about your bearings.
I am worried about the kids here, ok? I don't want a generalized statement being put out that puts people in danger of breaking stuff.
Easier points to clarify things with:
1) A spacer on a wheel causes more stress on the bearing then without it.
2) If for whatever reason, you can't get the -10 offset wheel and settle for the 0 offset wheel OF THE SAME WIDTH but use a 10mm spacer, you are in the same boat you would be if the had gotten the -10 offset wheel, it is not different for the bearing.
2.1) ^ however, running that 0 offset wheel without the spacer will cause less stress to the bearing then with a spacer and consequentially the -10 offset wheel too, because they are the same.
I am not really disagreeing with you, just disagreeing on how to word a conclusion so people actually understand what is going on under their wheel wells.
i read this whole thread and I couldn't find out what the F you were trying to say. And only because I didn't like the way things were being presented, I stepped in.omgshawn wrote:So, first you disagree, then you agree? Do you realize I've been saying the same thing as him this whole time..
PyR0NiAk wrote:shawn has got this on point... using offset to achieve your tire position, puts the center of the wheel --0-- as to where using spacers to achieve your tire position puts the center of the wheel at -0--- Obviously, the 2nd one is going to increase the amount of stress.omgshawn wrote:It doesn't matter....What matters is when you add distance between the HUB and the WHEEL, thus creating more load
omgshawn wrote:The load is not transferred through the tires it's transferred through the hub. Adding spacers increases the distance between the hub and wheel mating surface thus adding more leverage, which means there is more force being applied. I thought this stuff was common sense..
omgshawn wrote:What? I never said anything about 2 things being bolted together changing anything...
And that is wrong. You again are not taking into account that spacers change the distance from the wheel to the hub, where it matters. That is where the load is being applied across to the bearings.
It's simple. The further out you move the wheel FACE from the HUB, the more force is implied on the bearings.
You are confused. He's saying quite the opposite of you:omgshawn wrote:So, first you disagree, then you agree? Do you realize I've been saying the same thing as him this whole time..
As for this:nissan_star wrote:2) If for whatever reason, you can't get the -10 offset wheel and settle for the 0 offset wheel OF THE SAME WIDTH but use a 10mm spacer, you are in the same boat you would be if the had gotten the -10 offset wheel, it is not different for the bearing.
I wish I had access to a cad programnissan_star wrote:^thank you, i hope I helped someone. I have a pdf of an autocad drawing I made, but i can't figure out how to post it yet.
Ahem. Not everyone. C'mon nowomgshawn wrote:... I said moving the wheel face further away from the hub will cause more stress. Everyone bitched that it wouldn't. Now you're agreeing with it. Do you see now?
Right. A spacer on a wheel does cause more stress on the bearing. So does a lower offset. You're still wrong.omgshawn wrote:![]()
You agreed with that.
Now go read my post. I said moving the wheel face further away from the hub will cause more stress. Everyone bitched that it wouldn't. Now you're agreeing with it. Do you see now?
My problem was that you used the word 'hub'. When I think of hub, I don't think of the wheel, i think of where the studs are attached. I don't like that because some people think of hub differently when a spacer is added to the wheel. In reality, it doesn't matter how far the hub is, it matters how far away from the bearing (i guess you could say hub here as well because the hub can't move in relation to the bearing because it is holding the studs in) the wheel is when it hits the ground.omgshawn wrote:That's just the first page. Unless there is a comprehension problem, I do not see how that is hard to understand
Dangit now I'm humming that hahaha my cube mate made a weird face at me. I think thats what I needed to step away from this. Thanks Scotty.scotty-2-forty wrote:<sings> ... CAN You feel THE LOve tonight ...
Bringing joy to the masses in times of turmoil ... it's what I do.Ender_Zero wrote:Dangit now I'm humming that hahaha my cube mate made a weird face at me. I think thats what I needed to step away from this. Thanks Scotty.scotty-2-forty wrote:<sings> ... CAN You feel THE LOve tonight ...
mattblancarte wrote:So it can be agreed upon that:
1) Given the chance, buy wheels with the appropriate offset and fitment.
2) In the case that you need them, spacers will not destroy your wheel bearings if properly installed and maintenance is performed appropriately.
