What was done to your 240 today?
float_6969
Adjusted fuel pressure, installed wideband, set ignition timing, did rough tune on SDS EM4-4F, and drove it for the first time in 9 months!!!! I have a lot of tuning to do, but this big T04E is spooling by 4K-4.5K! Not bad for a CA18DET. Didn't get past that because I have a boost cut programmed at 15psi, but it broke the tires loose in 1st and 2nd as soon as the turbo spooled. This thing's gonna be a blast at 8500 and 30psi!
britter
Car: 1991 Nissan 240sx
replaced thermostate and radiator cap. drained all the water that the previous owner had filled with and replaced with coolent. had fun bleeding the system but she is all better now!
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Finishing installing the drivetrain on the sr, attempted to install my isis ic kit but s*** dont fit right.
novocaine
Car: 1991 240sx
installed optima redtop; painted wiper arms and cowl.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
JonathanPrem wrote:attempted to install my isis ic kit but s*** dont fit right.
You most likely have a pipe upside down, or the hole in the battery tray cut wrong.
JonathanPrem
I had the opening facing down. The top bracket bolted the hoodlatch prefectly but the bottom two brackets need to be re welded to that actually bolt on. cold pipe was almost prefect. I need better coupling hotside i didnt even bother since i had isis mani and the kit came for stock mani
PyR0NiAk
O... you mean the intercooler itself. My greddy's bottom ones don't line up with anything at all... If your couplers are tight, the I/C mounts really don't matter that much. Mine rolled around for 2 months without even being bolted to the latch.
z_K
Car: Ashy Larry
i started mine up after a fresh rebuild :cool:
http://www.youtube.com/watch?v=2Lz6iph8UWE
float_6969
Rebuilt pump and motor for air-water intercooler, and built bracket to mount said pump.
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
installed my Fortune-Auto rucas yesterday...finished my rear suspension setup.
tEknoS13
Car: 93' Type X
^^ that looks delicious. On the topic at hand, I got my car started again but it was running funny. It was up at 2500 rpms and fluctuated to 3k... I guess undoing the clamp from the hot pipe has something to do with it?? BTW: vehicle was just started for the first time after 4 years, so not vacuum lines are hooked up. First time it ran rather smooth, now its kinda scary.
Hooked on 240
Opened the garage door.
Felt the 9 Degrees of NY winter
Noticed i was out of propane for the heater
Went back inside and watched family guy
hudy
Car: 1991 240SX SE Hatch
Installed isis front tension rods, rear toe rods, test pipe, and 4 wheel alignment. It is handling much better now. Doesn't get the "trammel" over ruts in the highway near as bad as before. Not nearly as harsh as of a ride as I expected it to be. I would say it made it more "crisp?" It also drives straight! yay!!!
Didn't notice any improvement with the test pipe other than it fixed the exhaust leak that I had at the converter flange. So a little bit quieter ride is an improvement I guess.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Parked her after an almost 1000 mile drive.
h2v7
Car: 240sx s13
fuel pump left me stranded. pump was from 1989 so it had a gooood run.
so replaced that and fuel filter too.
it still has like the tiniest little bit of surge in power does it sound like i need to advance or retard my timing?
only does it from like 2k to 3k or so.
S133P3R
Car: 1989 S13 240sx
loaded a KA24E blok into my HB S13, drove the junkyard and found out the guy who worked there satruday was wrong - you cant drop off engine blocks there...
yay.
now i have a dual cam, in the form of 2 single cam engines. guess im hauling this thing around till i can get to the scrap yard. =(
FBMBMX240sxSR20
Car: 1995 240sx SR20
1964 Ford Thunderbird
Today I did a oil change
Resealed the turbo return line, I used a Volvo gasket because it's the exact same fitting to the turbo. I also replaced that hose on the return line I used another Volvo hose. It was exact fit. Lol I just had to make it a bit shorter but it was a good fit.
I got my inc. check today. And ordered a ton of parts :crazy: :biggrin:
Yesterday
I installed my new I.C
Tomorrow
I'm doing the 4 point seat belts.
And what ever else I feel like
britter
replaced slave cylinder and removed the factory damper box. Got a little more clutch feel but nothing crazy. Also the oil pressure sending unit went so replaced that and did an oil change. Back up and running with no more leaks!
S13Lovell
Car: 98 180sx
I ordered my 180sx :biggrin:
JDM240SXcoupe
Car: 1992 240sx coupe
1991 Crx Si
Bought a silvia front end..yeeeah!
S133P3R
Car: 1989 S13 240sx
realized i was driving arond with a bottle of spilled liquid detergent in the area formerly know as my back seat. :eek: looks liek sewer slime.
danshaz82
at least itll smell good haha
i got these bad boys in the mail
:biggrin:
S133P3R
Car: 1989 S13 240sx
danshaz82 wrote:at least itll smell good haha
:biggrin:
I post spilled detergent and you just had to post the sexiest coils you can buy to follow? Jeez now I'm jealous.
danshaz82
:rotfl
i couldnt help it!
h2v7
Car: 240sx s13
you dont need them sell them to me they are sold out till april!!!!!
S13_RB25
Car: A 240 but no RB yet!
Did a oil change, washed her and did the timing again. Runs smooth now! :)
Fenris
Car: 2011 Subaru WRX
1989 Nissan 240SX
Got my wiring specialties SR harness and then had to do errands all day rather than work on the car :(
JonathanPrem
Bolted my elbow on which is the worst job ever. Do it while it outside guys .
danshaz82
h2v7 wrote:you dont need them sell them to me they are sold out till april!!!!!
I tried to pm ya back, but you have them disabled. I believe that the new competition ones are sold out till April. The pros, which I got, should still be in stock. Unless I got the last set haha.
youngc20
i looked for a way for me to not cut my bottom bumper off to put in my intercooler
