WC's never ending s13 project
White Comet
Car: fc, s13 and mazda6, Sierra
mrgreeneyes wrote:fantastic. how hard does the bedliner dry to? and how much have you used so far?
not sure how much i used, but i'll probably need more to finish everything up. the truck bed liner dries very hard. im putting thick coats on so its nice and strong and resistant to wear. you'll have to check it out in person
spooled240 wrote:awesome, all that hard work is definitely showing
Oh and JDM AERO FTMFW!!!
thanks man, glad your liking it, and yeah jdm aero is indeed ftw
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
diff looks really clean & brand new!!!
good choice on bedliner...i did the same thing. great minds think alike
White Comet
very minor update-basically i've been sick since sunday, and it rained monday and tuesday anyways, so yesterday was the only day i felt good enough to do anything. my original plan was to truck bed line the other rear fender well, but when i got in there to start prepping it, i took a better look at that rusted out area behind the driver side rear wheel (i think you can see it in previous pics). i didnt want to truck bed line over a patch that already had rust so i busted out the dremel and started cutting the inside portion on the rusted patch. basically theres a little grommet back there that lets some water in, and the water doesnt flow out of the grommet as easily as it flows in so with nowhere to go the water sits in there until its rusts. i cut back past the grommet to where there was good metal. im debating whether i should weld a piece in there now to seal it up or if i should leave that cavity open in case any water does get in, then it can easily drain out. i was going to leave the exterior part on the rust back there for later but i had the stuff out so i figured what the hell, and cut that out too. on saturday i'll be cutting a chunk out of my old hatch and welding it in place of the bad section. on to the pics!!
heres the inner part of the rust that was cut out
and heres the exterior part thats gone in favor of good metal
the old piece removed, phuck you, rust!!!
cmoody2006
Car: 1993 Nissan 240sx vert
Man I'm not the only one around thats not feeling well right now I had quite an update on mine but that was a couple days ago haven't felt good enough to do anything for a while since it's getting cold out You've got quite a bit of rust under there.... Hope you can get it all clean
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
cmoody, if you think THAT is a lot of rust (its not, seen the car in person/worked on it many times already)... then you didnt see the underlying death on his black shell... that thing was a timebomb of rot... hence his getting a new shell, it wasnt just for fun
cmoody2006
I've seen some pretty bad ones... A friend of mine had one that had NO frame under it at all! Not one section was still in tact it all rusted off! It amazed me how the thing didn't fall in 2. I posted pic's on my build of the rust issue on my hatch... it's pretty bad but fixable still... I'm just not one to mess with rust! I like my new florida shell non-rusted
White Comet
I'm feeling too lazy to update, but i will anyways since im not up to anything else right now. I spent a little chunk of Halloween night and saturday afternoon working on the car to make a little more progress. Halloween night got dark so i busted out the flood light.i basically finished prepping the driver side fender well for truck bed liner and started cleaning up the rear subframe.sanding was going pretty slow, so i went on a run to get a rust remover gel that didderson has used with great success and a wire wheel attachment for my drill. i wire wheeled it a little and coated it with the rust remover gel. the bottle said to wait 5-10 minutes for light rust, and since i like to go overboard, i applied a thick coat of the gel to sit and work overnight.i also used the same stuff on my fuel pump cover.
heres the fender well fully truck bed lined.
before-
After-
after even more work heres how i left the subframe, its slowly cleaning up
i spent the rest of the time before work trying to remove the rear tow hook on the exhaust side without cutting it. real pita but i think i can get it. enjoy the update til monday
White Comet
alright, no update going on for awhile. i worked today til 3:30pm and it got dark by the time i would have been ready to work on the car. tomorrow and wednesday i work 8 am til close so no chance of progress at all til thursday at the latest. hope my latest update will hold you over til then (if anyone really reads this that is)
mRodiek
Car: Stock Hatch
WTF TIL THURS?!i CANNOT wait that long lol jki guess ill try =[ill be in grant park [chicago] tomorrow so i wont be on to miss nothing lolkeep the updates man! keeps me motivated!
White Comet
glad this is motivating you. im really itching to have a final product
cmoody2006
White Comet wrote:glad this is motivating you. im really itching to have a final product
You and me both! Once I get mine on the road - prob won't be till spring....
I'm gonna make a road trip to PA... My cuz lives there and I wanna swing in to check your car out in person
My progress has come to a stand still b/c of work... So i know how ya feel no time to do anything it seems like
But luckily - I'm off work today so this mean's I'll get some work done around the house and maybe get my motor swapped over to the new shell...
Also goin to go play guitar with a band tonght So that should be fun have fun at work
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
i wanna see an update on your wire tuck ...hehe i still cant decide on mine yet
ZenkiFactor
Car: 1996 240SX SE
I must have missed it but what did you use to coat the wheel wells and the sub-frame? Looks really nice!
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
iirc he used truck bed liner... it looks really clean
any updates?
this might sound stupid but is truck bed liner a spray on paint or something you do with a brush? it looks really think to come out of a spray can
i want to do this over winter but i will be in a garage so i gotta watch for fumes
Rin5
2 big $10 walmart electric fans (box looking ones) should be sufficient
S13Teddy
Car: R32 Skyline, S13
I want your babies.
hbpignosePA
90 Volvo 240 (sold)
what was that in reference to?
spooled240
Car: kouki s14
so what is your goal WC? having a 180sx type X that's show car condition? There's definitely a lot of patience and attention to detail
White Comet
Rin5 wrote:i wanna see an update on your wire tuck ...hehe i still cant decide on mine yet
mine's not finished yet but it'll be done soon. right now im trying to get the underside and exterior crap done so i can do the swap and wiring in the garage
ZenkiFactor wrote:I must have missed it but what did you use to coat the wheel wells and the sub-frame? Looks really nice!
hb is right, its duplicolor truck bed liner. its fantastic stuff. great bang for the buck
hbpignosePA wrote:iirc he used truck bed liner... it looks really clean
any updates?
im uploading pics right now, so i'll have a little update. the truck bed liner is brush one or roll on. there are instructions for using a spray gun though. brushing is what im doing. you should be fine in a garage. the stuff smells a little strong though
S13Teddy wrote:I want your babies.
i've anticipated this turn of events and have prepared for it
spooled240 wrote:so what is your goal WC? having a 180sx type X that's show car condition? There's definitely a lot of patience and attention to detail
i def dont want it to be a show car, but thats the kind of detail im ending up putting into it. its gonna be my daily that sees track time. the fc is my baby that will be for nice weather only.
uploading pics for an update, sit tight
White Comet
this isnt a huge update but im happy with the progress i've made in a short time ive had. i had off thursday and saturday last week, but its was raining and miserable both day. no progress was made . i worked 11:30 to 5 on monday and was able to get some work done on the car from 7am til 10:30 and then from like 6pm til 9pm. today was 8 am til 9 pm so no progress from today. i did on monday manage to finish prepping and completely coat the rear subframe with truck bed liner (sorry for the cell phone pics, my camera is mia)
then i started disassembling the the rear uprights, axles and rear lower control arms.
one of the axle boots was ripped so im using the one off of the black car, i also removed the rlca from the upright for ease of pressing out the remaining bushings. im also picking up new rear lower ball joints to go in before everything is reassembled. im dropping the pieces off tomorrow to have the bushings removed.
heres the axle and random hardware
i got some more of the es bushings pressed in as well. i finally got the knack of it and the bushings are going in easy now.
tomorrow im dropping off the the rlcas and uprights for bushing removal. im gonna clean up and remove my other axle needed from the black car, and start sanding down the rear underbody. if i have enough time i'll start coating some of the stuff with truck bed liner. after thats dry i can reinstall the gas tank and so on. i have a bunch of parts coming in that im waiting on, i'll post pics and details as they come in. i'll have more to update tomorrow.
Chris28
Car: 92 s13 KA-T
Looks great man, I'm about to drop my rear subframe to fix a stripped diff bolt hole, and I'll probably clean it up nice and shiny like yours then bed liner it before slapping it back in. Luckily the winters down here are nowhere near as harsh as PA so my underbody has like 0 rust haha. Keep it up, it looks like a lot of progress is being made.
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Nice job so far jeff. I'm really interested in how the bed liner holds up within a few months of PA driving.Having those nice bushings in next you're going to want solid ones that are included with new PBM parts hehe.
I want to know if the z32 rear knuckles fit the 240 because i read in sport compact car that they did (way back in the day when i read that one).
Ever heard of this? reason being is because we're both working on our subframes...
White Comet
i think i vaguely heard about the z32 rear knuckle but never looked into it at all? would it be better then the stock one (just wondering why its worth it)
glad you like it chris, the car has little problem spots, but important areas like teh rails are flawless you i wouldnt have bought it
mrgreeneyes
Car: ///M5
quick heads up homie, NOONE sells the rear ball joint properly.
the b13 sentra RIG is a no-go, the tapers are wrong...
gotta buy the whole rear LCA with balljoint from nissan...
tramp_drift240
Car: 1992 240sx SE Coupe
lol.
ive got s13 LCAs.
mrgreeneyes
Car: ///M5
tramp_drift240 wrote:lol.
ive got s13 LCAs.
new ones? ill buy em
spooled240
Car: kouki s14
ey it might be a good time to get some aluminum z32 uprights and drop 14-16 lbs of unsprung weight. IIRC all that is needed is the conical ball joint seat (part # 40173-33P00) which is about 10 bux from the nissan dealer.
White Comet
mrgreeneyes wrote:quick heads up homie, NOONE sells the rear ball joint properly.
really? you can get moog rear ball joints, not b13 **** either, the part number is for the s13
spooled240 wrote:ey it might be a good time to get some aluminum z32 uprights and drop 14-16 lbs of unsprung weight. IIRC all that is needed is the conical ball joint seat (part # 40173-33P00) which is about 10 bux from the nissan dealer.
i'd def get z32 uprights but then the stock rear struts would no longer fit
Chris28
Car: 92 s13 KA-T
Well there's your excuse to get coils! Problem is finding just s13 fronts and z32 rears.
White Comet
from what i've read the z32 spring rates woudl not be ideal for teh s13 since theyre designed for a much heavier car. besides i dont have the money to get coils yet. but i will eventually. i just got off work early since i got someone to cover my 2nd shift. i'm going over to work on the car asap
