White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Wed Oct 22, 2008 3:25 am
thanks for teh props nostalGic_RPS13, im glad your enjoying it. and yeah its def worth the trouble to gather all the pieces.
keegan, sounds good let me know what day your free. im def down to work on another car for a change. mines pissing me off a little. nothing serious but the bushing install makes me want to punch a baby
heres a little update you asked for joshgot my diff completely finished up, the housing was given its final coat of semi gloss black and the diff cover was installed with new felpro gasket and then filled with royal purple gear oil. imo it looks really good with alum colored cover and black hardware
i started installing the bushings for the rear as well but they didnt want to go in at all and they were really pissing me off so i gave it a break to tackle something else. this is the only bushing i got in after hours of trying
i got frustrated with the rear sub frame bushings as well. i spent about an hour getting 1 rubber bushing out and thats not including the metal ring that needs to come out too. so i got tired of that too and dropped it off at a machine shop for them to see if they can push em out. heres pics of the progress i made with it thoughand hear im trying to burn the rest of the rubber out, it didnt really do the job though
next, i moved onto the rear wheel wells. i found theres a spot that commonly rusts the seam out and leaves a gap. i got out all thee loose debris and filed everything out and caulked it shut, heres the caulking and before pics of teh wheel wellheres the scrubbed down and sanded pics of the pass side
heres the pass side semi cleaned up, still needs some work though
heres 2 coats on the pass side, pretty much done
and some bonus pics of my new "cat"
i left for teh night with the sohc temp sensor soaking in evaporust. im heading over right now so we'll see how it looks after soaking all night
