White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Thu Jun 11, 2009 6:58 pm
yeah man let me know more details when you go check it out. i have a pretty picture heavy update so here it is.
for starters i've been spending my time getting the new doors ready to go. its been raining at least a little every day this week so i've been doing what i can. i found a few low spots and learned that the car had a kinda s***ty respray at some point but it wasnt a problem at all. i removed the door handle and weather stripping to do a legit job on it. the handle actually had some chipped up paint that was hard to get to. i discovered this when i hit it with primer.i just pulled the handle off of my spare black door and prepped it for paint.
the manifold was sandblasted and then i started sanding, grinding and filing.
this helped with the sanding off the manifoldand now i'm just hitting it with a flap disk after i grind down the overhang in the inlet flange.
i started doing a little bondo work on the driver side door, much to my surprise the professional gold bondo was actually gold colored. what really sold me was the fd on the label hahaha.
the spot near the handle was easy to fix
i'm still working on the other spot. i just needed to fill in a little low spot and i still need to sand it. i bondoed it last night at 2am and will finish it tomorrow after work. since i was up til almost 4am i slept all day lol.
a sanding block makes the work so easy
my little brother is interested in getting an s13 so he's been helping me with mine. i put him to work on the pass door while i worked on the driver side one. i had him pull off the weather stripping then pop all the little clips back in. it's a b**** isn't it, cody? lolthen he masked everything off and started sanding
i had the handles all sanded down and prepped so i started painting them. i used a little wad of tape to hold the handle up to spray under it.
the driver side still needs to get painted red but the pass side is done
the pass side door got 3 coats of red and dried all day today. paint laid perfectly and came out really nicely.
door jambs came out nicely too
didnt take a pic of it earlier but heres the turbo shield.i'm def getting a heat shield for the brake master cylinder, its a little tight.
sprayed the little handle for the glove box since i switched over for the latch for the key set i have
kinda blurry pic, but heres the old welding mask vs the new one i bought
keegan stopped by to install the alarm since it was all prewired and ready to go. still looks messy but this is it, 99% installedheres the keypads
keegan's stealthy alarm led mounting, so discreet
after keegan left i kept worknig on body stuff and finally resprayed the roofone pic is with flash and one withoutmy whole work area
now on to the pics you've been waiting for........turbo fitment. when keegan first got there we mocked it all up.
i just held the turbo instead of bolting it fully down, but the dipstick tube clearly has to be moved
the wg and screamer pipe after i cut it to fitthis is what i cut so the screamer pipe wouldnt hit the frame rail
heres the wg without teh turbo in the way
not much clearance for the wg, its very tight but will work.
more coming tomorrow
