Didderson wrote:Lookin good jeff. I'm torn between the relocation of PS lines because idk, the rubber lines are longer and the fender well had to be drilled out more, but it will free up that space. You won't notice the PS reservoir behind the hotpipe tho err I mean mine gets in the way, dunno how yours will be. I'm just weighing the trade offs for ya, imo I won't be relocating ever unless something better comes up. How are u going to have it in there w the clutch master, does it fit?
You should get an oil cooler for that relocation or just put the stock filter back on until you have one. Takin' off the manifold brackets will allow you to do an oem filter change with your bare hands s0n.
yeah the ps lines are longer of course but kept out of the way by being secured to the frame rail far away from the turbo. as for the fender well, i had to drill 2 holes near where the green wiper amp goes so its no big deal. i decided to relocate cuz the new location is cleaner and out of the way and i had the ps res off anyways. it'll fit perfectly next to the clutch master with the modification i showed you when you stopped by. i cut off the lowest mount to drop it in nicely, bent the brackets so they fit on a straight surface, and bent the lower, larger tube into more of a 90* angle. everything will fit perfectly and i'll have finished pics tomorrow.
as for the oil cooler, its a good idea and i've been thinking about it for the future, but i don't see a reason not to run my relocation kit because i don't have a cooler. the relocation lines are already hooked up and run, and i'll be running a much larger filter pushed to the front getting some airflow as it is. i don't see the benefit in removing the relocation kit i've already paid for and installed to use a stock filter. i kept the intake manifold brackets and i can still get the stock filter off with my hands, but i had everything apart already, it was only $60 and its def going to be much easier.
shmex wrote:Man ive been watching this thread for so dang long...hahahaha....
Good updates, and thank goodness you changed the turbo's red, to that black. Cuz that shiz was ugly.
yeah subbie guys love wrinkle red but not me. glad your still following this, the next few days should be interesting.
nothing really to update, i spent all day cleaning the old apartment and tieing up loose ends with that, but i'm finally out of there officially and getting the security deposit back in a few days. i did receive a box today though, these were insidei think you can see where i'm going with this
my sidekick as i was uploading pics
the T's need trimmed a little and so does the flange but it should be welded up tomorrow or fri depending on when my brother's free.
my mom texted me and said the new isis top mount lines came in today too. should be an exciting day tomorrow.
