Zippy69 »
https://forums.nicoclub.com/zippy69-u73952.html
Fri Nov 09, 2007 3:13 pm
Ok, I got everything set and hooked up, I checked and rechecked all connections.I turned the engine over with coil wire off to circulate oil and get gas to the engine.I reconnected the coil wire and tried to start it and it started up and stumbled.I tried to start it again and it just kept turning over and over like it had no fuel and or no spark. Checked both and both ok. I then noticed all warning lights on dash(oil,seatbelt,check engine,brake,battery) were on. Turned ignition off and lights still on. I took out key and the lights were still on.I checked my ignition switch and it seems ok. I disconnected the battery and waited a bit and reconnected it, the lights were out until I tried to start the car then lights back on.I swapped back to my original ecu, and the the lights stayed out but the car still would not start, maybe it was flooded ,not sure.I think my ecu may be bad, so I called Jason at E-mance and he said he would replace it.If anybody has any idea of something I may have missed or what I can try, PLEASE, nay PRETTY PLEASE let me know.My set up is a t-25, 550cc deastchwerks,and an n-60 mafs.
