Add a bigger catch can to that too.Broadfield wrote:
And since I am going to need to get the thing re-tuned, I am going to drop in some Toda springs, retainers and RAS's to compliment my Toda cams. I'll keep you updated, but for now, this is how she stands,
Yeah, the only thing I am fighting with is keeping the AC. The manifold I really want is not AC friendly.... or at least I have to double confirm it. If it was AC compatible, there would be no choice. Are you still going to use the GT2871R?driftfan420 wrote:Hey broadfield, let me know when you decide to purchase your manifold and which brand you're deciding on going with. I'm in the market also, and figured we might be able to save each other some cash by maybe getting a group buy. I have a set up similar to yours.
Yeah, yeah I'm on top of the bigger catch can thing! Don't get your pooped stained boxers all up in a bind!ladysman wrote:
If that turbo wouldn't have let go, I can tell you the manifold would have.
Don't worry guys, we'll get her back up and running. Hopefully we can finish my car first... yeah right.
Already approved...dikBroadfield wrote:Hell, even if we did get your car finished first, you would still have to get clearance from upper management to drive it.
With the backets I make and sell, you really can't go 'to much' lower than what I already make, in order to clear the pan. To top it off, you also fight sway bar fitment issues in the front as well then.Broadfield wrote:I'm not sure how much lower I will need to go on the compressor..... have to wait until I get the manifold. Which is a 6-8 week wait by-the-way! I can only go about a little over an inch lower before it hits my Greddy oil pan. If I need to go lower than that I will put a stock pan back on and run a oil cooler if need be.
Actually, my friend has one of your brackets.... or at least I think it's you. It's made to use the OEM KA compressor.codyace wrote:
When done, see if you can get some detailed pics of the T/S manifold and it's fitment
PS: It's going to close to a .86 2871r in spoool. Slightly after, but negligble at best of a differnece.
Sorry dude! Yes, you can polish it yourself as long as you don't mind a lot of elbow grease. I will polish the compressor side once I get it. Basically I will grind down the major raised areas with a grinder. I will then use a air sander with 36 grit then 50, 80 then a mini DA sander 120, 180, 220, 300, 400, 600, 800, 1000, 1500, 2000 then Hoosier metal polish.... done!inkslingers13 wrote:did you read my post???? polished???? ^^^^^^^^
Oh yeah, I will let you know.... that is the point of this thread. I went with the 71 because it is my daily driver. I want good response on the street but still put down more hp than my old setup. I'm not worried about 1/4 mile times..... I'm lucky enough to get a Sunday off.driftfan420 wrote:Broadfield, let me know if you get something fabricated. I'm running the greddy oil pan also. if you can figure something out please share it with us. I'd love to go with the twin scroll, but it looks like i'm going to end up with the full race T4 ProStreet Turbo Manifold or the peakboost manifold. what made you decide to run the 3071 instead of the 3076?
You fund it, I'll build it! I don't think your wife will mind.ladysman wrote:Lets build the block while we are at it.
That's why you grind the letters off!inkslingers13 wrote:i was wondering because of all the PITA spots around the letters. thanks, ima give it a shot
