Didderson »
https://forums.nicoclub.com/didderson-u38557.html
Fri Jan 11, 2008 10:49 pm
Thanks moldy! I just research before I act. I didn't know much about them 2 months ago .
Update: battery box done, upper wiring harness in, IC piping finally all done, battery tray area cleaned/painted some new goodies for the radiator hoses. The wire tuck/hide is amazing. Sorry we had to work fast, me and mr.greeneyes because of time constraints tonight.
First few pics are kind of a write up on how to do the battery box. It takes awhile to measure where to put the first pin, but drill the first one from the area that'll be hardest to match up and then the rest from the top. I believe NHRA and SCCA require at least 3 bolts bolting the battery box and or battery down if not stock, so i did 3 12" bolts from home depot with lots of washers and nuts.The underside after drilling
Topside with loose installation.
Battery box down, mock the holes up for those bolts on the box itself before you drill holes and use it as a template. Make sure u don't forget to put the carpet on first because I forgot and have yet to fix it lol.
If you don't have a friend to hold a wrench wedge it up against the box as u tighten the bottom nut. Luckily my bro got home 5 mins later and helped me.
Buy a rod of alluminum from home depot, measure and cut. Install as pictured:
Wiring in! check it!
Injector wires? What injector wires... all wires were run right by the coolant line going from the thermostat to the back of the motor.
Rad hose got a stainless steel treat, IC piping done, u can see the hidden wiring here too:
Pic of how i mounted the intercooler. stealth and lightweight homemade alluminum brackets. I forgot to take a pic but I also found a good use for canadian twonies or 2 dollar coins... to clamp off the old bov flange as a second wall lol.
That is all, I'm just waiting on my pipingpro.com kit for the intake, my Powered by MAX catch tank, and the Apexi SAFC2 that will hopefully be wired up tomorrow to help run the N60 MAF.
