yes its the factory s14 ECU. could i delete the limiter or do i need to get stand alone engine management?PapaSmurf2k3 wrote:Are you on the factory ECU? They have speed limiters in them.
You should be able to just clean the splash fouled plugs, or spend the ~$10 on new ones.jbreze wrote:Hi again.
Is it okay to reuse splash-fouled spark plugs? My new plugs look splash-fouled according to this guide http://www.gnttype.org/techarea/engine/plugs.html mine are not that bad though
If the gap on one spark plug is off, will it mess with the AFR? I'm running very rich. I smell gas in my oil and out the exhaust.
I will be testing the FPR and the valves
some info
-pulled fuel rail for pressurized test. no leaks
-cleaned MAFS with windex
-smooth 800 rpm idle
-tested TPS and coolant temp sensor. all within specs according to tutorial
-new o2 sensor, fuel filter, wires, cap, rotor, PCV valve
-cleaned IACV, PAIR valves
-good compression (180-180-180-160/170)
While the engine was running i unscrewed the oil cap and i felt pulsating air. Is this normal?
Thank you
allenms240 wrote:Papasmurf,
Thanks for all your help, this is why I come here with my problems. I had the wrong bearing cap on. I had swapped 1 and 5.
I found diffs to vary even within chassis years (like halfshaft output/bolt pattern). Best to get a picture of one and compare it to your own for optimum ease of swappage.Toxsyl wrote:So far it's reverse since I never checked the others.
I'll check fluids tomorrow.
So how much is a full clutch? Price ranges for something stock for now.
Edit: The S13 and S14 VLSD rear diffs are the exact same? I'm thinking of trying my luck on the classifieds if this is true.
On the intake tube there should be a few "boxes" coming off of it (assuming it's stock). Those are resonators meant to quiet the intake down. You should be able to remove one of those, or you could try your luck with the hose that goes to the valve cover too.jbreze wrote:So i adjusted my idle and i had to turn the screw all the way in until it wouldn't turn anymore. With TPS back on the idle is about 750. Then i checked my timing with a light. It was off 1 notch. I also set my spark plug gaps to .044. The exhaust still smells like gas after all that.
It smells when engine both hot and cold.
When you say "disconnect one of the resonators", are you talking about one of the 2 visible hoses on the air box intake? between the throttle and the MAF sensor?
I bought a fuel pressure gauge kit and a vacuum pump, so i will be testing the pressure and the FPR
