also, the new KA thats going in doesnt have that. is that a problem?
Pilot bushing? I remember mine being ON the crankshaft though.danshaz82 wrote:whats the little brass nipple looking thing? i remember reading it somewhere a few years ago
I have a 92 so it might well be different, but everything done to the driver lock, the passenger lock does, wether you turn they key or do it from the inside, the passenger lock follows. When you operate the passenger lock, the driver lock does nothing.sunhawk wrote:i have A 95 se model. shouldn't both doors unlock when i turn the key clockwise in the driver side door key lock cylinder?
Are you good at soldering?danshaz82 wrote:does this look fixable? theres a small piece of the wire sticking out from the plug. its the male end of the VSS
would i be able to put the stripped part of the wire into the plug if i pulled the broken part out? or would i be better of soldering?
Either or would be fine. If it's strictly a daily driver, I'd probably go with OEM. If you drive it at all spirited, do either. If you track it at all, go with urethane.sunhawk wrote:i have a 95 se manual for my daily driver and wondering. if i replace bushings should i go with an oem type product or urethane?
Will it do it with the car off/not running? Is there anything stopping the actual lever itself from going into 5th?rb20dethelp wrote:Hello, im looking at buying a nissan harbody pickup truck, but it actually has an rb20det in it, but the transmission wont physically go into fifth... can anybody help me?
Just unbolt the slave from the trans. You don't need to open the hydraulic system at all.mechanicalmoron wrote:To remove the transmission, does one have to move or drain any clutch hard lines? Or is there a soft section to the little squishy-izing block assembly, and then another to the slave?
And, when doing a clutch job, how much farther out of the way is it to get the rear engine oil seal? I'm not finding the picture I need in the FSM, but the flywheel needs to come off? And how much else? How much extra time, assuming I have compitent help and have already found all the info and FSM stuff I need?
And are there any torque to yield bolds or gaskets or anything else I should know about, that won't come in a standard oem-type (auto-zone) clutch kit?
charat wrote:So i'm in the process of what is basically rebuilding my 240sx... I'm trying to get some numbers. I want to go from a brown interior to a black one. Minus the seats, how much would it cost me for a full black interior?
I was hoping to get away without resurfacing the flywheel, given the condition of the motor and the fact that I'm putting a 100 dollar clutch in. I'm only doing the clutch because the current one is very bad, and at this rate, will fail before the motor -- but it's a stop-gap measure to squeeze life out of the current drivetrain, and I don't want to spend money on a flywheel, and won't have time to get it resurfaced, I'll be using a lift/shop that I really only have access to for a day, wanted to do it all in one session.PapaSmurf2k3 wrote:Just unbolt the slave from the trans. You don't need to open the hydraulic system at all.mechanicalmoron wrote:To remove the transmission, does one have to move or drain any clutch hard lines? Or is there a soft section to the little squishy-izing block assembly, and then another to the slave?
To do the rear main seal, you have to pull the flywheel, which you should do anyway to get it resurfaced or replaced. After that, its about a 10 minute job.
When doing a clutch, the things you should have/replace are:
Clutch disk
pressure plate
flywheel (either resurface or replace)
Throw out bearing
inspect pivot fork bolt
Rear main seal is a great idea
you'll also need fresh gear oil... as I'm sure yours will leak out when you pull the drive shaft.
It hardly grabs, it bites almost at the top of the pedal travel, which is a dramatic change.PapaSmurf2k3 wrote:yeah, just unbolt that carrier bearing and unbolt it from the rear diff to remove the whole thing.
I've never done a clutch job without doing the flywheel. The clutch sort of wears a big ring into the flywheel, and if either the disk is a slightly different size than the old one, or there is any misalignment whatsoever, you'll end up clipping the outside of that ring and your clutch would probably last all of about 5 minutes.
...and what do you mean re-gap the current clutch?
If the clutch isn't slipping, why would you replace it? What symptoms is the car showing that makes you think you need to replace the clutch?
The only special tools you'll need are a torque wrench and the alignment tool, which comes in the kit.
